corsa extreme x pipe
Old Jun 22, 2022 | 05:01 PM
Grapela's Avatar
Grapela
Default corsa extreme x pipe
Long time z owner here and want to finally upgrade the exhaust from the stock titanium. i want a corsa extreme but am confused if I need the xpipe as well. I currently have LG streets with the catted pipe so do I replace that with the corsa or is the corsa x pipe for people with stock headers and I just need the cat back?
I am confused.
thanks
Old Jun 22, 2022 | 05:08 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
You will almost certainly be fine with the x-pipe that you already have. You would only need to change it if your were going to swap headers as well. The Stock Z06 exhaust is in high demand. Once you're certain you want to keep the Corsa, you could probably recoup a good bit of your costs by selling the TI exhaust that you're currently using.
Old Jun 22, 2022 | 10:07 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
The Corsa extreme will bolt right up to your LG mid/x pipe.
Old Jun 23, 2022 | 01:02 PM
Grapela's Avatar
Grapela
Thanks all, thinking I will keep the TI for if I ever sell.
To corsa extreme x pipe
