Tunnel Plate
Old Jul 5, 2022 | 10:32 AM
JCMDoug's Avatar
JCMDoug
Default Tunnel Plate
In the next few weeks I am finally going to change the diff/gearing on my 2002 A4.
During the process the tunnel Plate comes off so should I upgrade to a stiffer tunnel plate, Per TPS Motorsports "eliminate many creaks and chassis flex due to the increase thickness and rigidity of our plate"
I don't race the car it's more of (while the plate is off put on a better one) or is this just a waste of money for a daily driver.
Old Jul 5, 2022 | 10:43 AM
schmuckingham's Avatar
schmuckingham
I have heard people say that for Vert or Targas they can make a difference. You can also use one from a C6 that is a bit thicker.
The best investment in my eyes would be some type of heat shielding on the tunnel plate instead of replacing it.
Old Jul 5, 2022 | 11:35 AM
JCMDoug's Avatar
JCMDoug
Yes heat shielding thanks for idea, I will most definitely add it.
Old Jul 5, 2022 | 11:50 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
You can get an aftermarket tunnel plate that is both thicker, and has integrated heat shielding. This will maximize the effectiveness of the mod by lowering cabin temps while also making the car stiffer. I've heard the thicker plate really does make a difference when cornering, but if all you do is cruise, then you likely don't need it. The heat shielding would be good regardless though.
Old Jul 5, 2022 | 02:01 PM
LowcountryVette's Avatar
LowcountryVette
I may be in the minority but I have an elite engineering tunnel plate with heat shielding and I havent noticed a significant difference in cabin temps. I’ve seen kits for heat shielding the top and sides of the tunnel, that may provide a more noticeable result.
Old Jul 5, 2022 | 02:04 PM
MWWarlord's Avatar
MWWarlord
How do you feel about the EE tunnel plate's impact on rigidity?
Old Jul 6, 2022 | 07:08 AM
JCMDoug's Avatar
JCMDoug
I ordered the elite engineering heat shielding. I am going to used my craftsman digital infrared thermometer and do a before and after, to see how the temps are affected.
I will try to match driving conditions (outside temp and distance traveled). My 37 mile back road trip home after work should do, and say 5 days of data points. (this is where my wife rolls her eyes at me)
Old Jul 6, 2022 | 11:09 AM
LowcountryVette
unfortunately I installed an AMT diff mount at the same time, so I cant say for sure how much of an impact just the plate has. I may go back to the stock diff mount at some point so I’ll try to remember to let you know then.
I will say the two together feel great, very noticeable effect on handling. But Im pretty sure most of that is from the diff mount. Ive got a pretty bad gear whine noise afterwards otherwise It would be my favorite mod yet.
Old Jul 6, 2022 | 12:13 PM
smitty2919's Avatar
smitty2919
You'll never notice any increased stiffness from a tunnel plate.
Adding heat shield will be you biggest measurable improvement. Look up the DEI tunnel kit to help as well.
https://www.designengineering.com/c5...-complete-kit/
Old Jul 6, 2022 | 02:48 PM
jjc508520's Avatar
jjc508520
ECS installed the insulated Elite plate while doing my headers - difference in cabin temp was noticeable. Later - when installing the rebuilt lower shift box - put some additional heat shielding down the sides and the helped even more....
Old Jul 6, 2022 | 03:13 PM
smitty2919's Avatar
smitty2919
I'd like to get back in my tunnel and go to town with insulation all round the TT and as far up the firewall I can.
Old Jul 6, 2022 | 05:11 PM
-stew-'s Avatar
-stew-
Do you have headers? My Commemorative Edition Z06 had headers and high flow catted x-pipe and tons of heat came from the tunnel. My Current Z06 has stock manifolds and cats and no noticeable heat from the tunnel. Both with the stock plate.
Old Jul 7, 2022 | 09:51 AM
LowcountryVette
Yes, headers w/ no cats
Old Jul 7, 2022 | 10:04 AM
milk4coffee's Avatar
milk4coffee
Thank you!
Old Dec 3, 2022 | 02:49 AM
vette4fl's Avatar
vette4fl
So, how did that work out?
Old Dec 7, 2022 | 07:59 AM
grinder11's Avatar
grinder11
Old Dec 7, 2022 | 08:06 AM
dom04abp's Avatar
dom04abp
You can pick up a C6 tunnel plate for pretty cheap. Spending 200+ on a tunnel plate just seemed over the top, better investing in the heat shielding as many have mentioned for a daily driver.
Old Dec 7, 2022 | 12:42 PM
JHrinsin's Avatar
JHrinsin
I picked up two (2) C6 factory plates (1/8" thick aluminum) for $79 and stacked them. Yes way cheaper than a 1/4" aftermarket unit and most likely just as effective.
Old Dec 7, 2022 | 01:16 PM
vette4fl's Avatar
vette4fl
I got 1 C6 plate here in the FS section for about $50. It’s armor compared to the stock beer can weight plate.
To Tunnel Plate
