[Z06] Calculating RWHP
The number one rating? Quarter Mile top speed, at 4.5. As many of us have said on this forum, trap speed is the best indicator of your RWHP.
The formula is RWHP = (mph/234)3 X weight (mph divided by 234, cube that number and then multiply by weight).
Our cars weigh roughly 3100 pounds, so if the driver weighs 200 pounds it goes like this:
115 MPH divided by 234 = .4914529
.4914529 cubed = .1186986
.1186986 X 3300 = 391.7
The article does allow that shifting ability on a manual has a big affect, and frankly I believe drag coefficient does as well. That said if you want to use the formula to see how much more HP it takes to push you car say 115 vs 119 MPH it is pretty accurate.
In my case I ran 115 MPH stock and now run 119+ with my mods, the above example is mine actually, so in theory I am making 434 RWHP on the top end (a bit high I believe) but the 43 additional ponies needed to run 119 vs 115 is about right with my mods, and not very different from the dyno.
Les
So what I'm saying is that 1/4 mile trap speed means alot, but it also means that's the power you were making under those conditions.
I ran 116.24 in the 1/4 but my car dynoed at only 354 yesterday. I was so dissapointed that when I got home I took the intake system apart and found out that my airbridge wasn't properly connected to the throttle body and was sucking air in at that point. I had been throwing lean codes since I put it on, and had to clear one right before the dyno. So my computer was pulling timing to compensate for the lean condition.
also, congrats on the Falcons big win last night, that was some impressive!
It's nice but it is waaaaaaaaaaaaaaaay to big!! :nono: :cheers:
I tried calculating for my last time to the track . . . I trapped 124.5 (stock turbos without Nitrous), but my highest dyno. on that setup was 503 RWHP. Using the formula (my car with me in it was 3,765 lbs.) . . . I get over 567 RWHP. I think because of the nature of turbochargers, the formula would come up artificially high?
I think with Superchargers and Nitrous Oxide, the formula would be more accurate 'cause of the nature of those methods.
And, I believe you're right about Coefficient of Drag having a big effect. Imagine a vehicle with a .08 Cd . . . it would of course have an easier time generating the speed at the traps.
I haven't read the article, but a dynomometer in good repair and calibration with accurate weather data to compute accurate correction factors is about as good as it gets.
Duke
Below are two formulas - the first, is the one already being discussed, the second one however adds something interesting. I originally read these in a Vette magazine, where they were testing a few C4 tuner cars (LPE, Rippie, etc) and they were kind of using them to validate the HP claims (vs. the actual ET/MPH).
The article indicated the Trap/MPH calculation would estimate OVERALL power the car was putting down. Then (and this is kinda interesting) the second formula would estimate HOW MUCH of that power was being utilized by the car (of course it doesn't take into account dozens of things).
It is interesting though to see a car generate 614HP from the MPH, but only derive 520 from the ET, meaning it has lots of "HP Loss" from traction, etc. (assuming, again, lots of other variables)
The Trap-speed method
This method uses the weight of the car and the speed at which the car completed the quarter-mile run.
The formula is: hp = weight * (speed / 234)3
The ET method
This method uses the weight of the car and the time it took that car to travel 1330 feet (¼ mile).
The formula is: hp = weight / (ET / 5.825)3
Here's a great source for the formulas (plus some other good stuff):
http://www.rpmoutlet.com/formula.htm
And the F-Body site has a bunch of these automated with [/img] Report this to a moderator
http://www.fbody.com/calc.htm
Take care -
Get your best price and then contact us Xtreme M.S.480-517-4969
