ac
Old Aug 16, 2022 | 10:54 AM
wayne100's Avatar
wayne100
Default ac
So my ac has been blowing through all the vents no matter how I set it. Found an old thread about it being a vacume problem, so I checked it. Pulled the battery and the tray and under it was a broken line. Bought some 5/32 hose and some larger tubing to fit over it hooked it up and pulled the access panel behind the passenger wheel and under the car to reach where it hooks up to. Had to take the screw out of the bottom of the fender to pull it out a little to reach the check valve where the line hooks up. Presto! now it works. Still have more problems with it, interior temp sensor shorted, ordered one from Vettenuts.
Old Aug 16, 2022 | 02:04 PM
docmow's Avatar
docmow
2021 C5 of the Year Finalist - Unmodified
good job
Old Aug 16, 2022 | 04:48 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I hope you are able to get everything squared away soon. Good Luck!
To ac
