Clutch reservoir
Old Aug 16, 2022 | 01:48 PM
vinco's Avatar
vinco
Default Clutch reservoir
Granted I'm not as strong as I was a year ago, but I cannot for the life of me remove the cap from the clutch reservoir by hand. I don't want to break it, so before I put the big channellocks to it, I thought I'd ask how it actually comes off. Do you push it down and then turn, or is it just straight threaded on there? It doesn't say on the cap.
Old Aug 16, 2022 | 02:47 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Just spin it off. Careful channel locks are un forgiving on plastic. I'd start with sloooooow steady pressure until it cracks.
Old Aug 16, 2022 | 03:36 PM
ThomasR's Avatar
ThomasR
The cap just unscrews. Use a pair of channel locks to hold the reservoir too.
Old Aug 16, 2022 | 03:49 PM
rrwirsi's Avatar
rrwirsi
If you have some gripper stuff they use in shelving, try wrapping that around the cap and turn. I agree, I would not use channel locks to remove. The caps are plastic and if your do Murphy's law may bite you.
Old Aug 16, 2022 | 05:37 PM
2010Pony's Avatar
2010Pony
I had a hard time getting mine off also finally I got it to brake loose with a good tug
Old Aug 18, 2022 | 09:46 AM
johnson-rod's Avatar
johnson-rod
Hot water on a rag.
Old Aug 21, 2022 | 11:18 PM
vinco's Avatar
vinco
Originally Posted by johnson-rod
Hot water on a rag.
This did not work, but it did inspire me to add some heat to the equation. I borrowed the wife's hairdryer and put it on the cap on high heat for a couple of minutes. I could feel that the cap was indeed warm, but alas that still wasn't quite enough to allow me to turn it by hand. However, while it was still warm I applied leverage via an adjustable wrench that is commonly used to tighten nuts on sink and shower drains, as pictured below. I set the wrench such that it did not squeeze the cap but was just snug on the smooth parts and would catch the raised ridges on the outside edge of the cap. While I had some pliers available to add extra leverage, they were not needed, and the cap actually turned fairly easily since I could get a better hold on it with the wrench.
Once opened, it became obvious that the fluid is in dire need of replacement, and I will do so by the Ranger method to try to improve the clutch feel.
Old Aug 21, 2022 | 11:38 PM
Gary In NM's Avatar
Gary In NM
Glad you finally got it off. I use a strap wrench as mine is pretty tight after it's been on a while, works perfect and won't hurt the cap.
To Clutch reservoir
