My C5 Restoration project.
Unfortunately, after talking with the licensing office, it'll be a little while before I can fully get the car on the road. Car has to be damn near 100% before they'll issue a title for it, and body panels are going to take some time to save funds for.
Oil pan should be showing up on tuesday, then I can FINALLY start putting parts back on this thing!
I'll try to get some pics tonight to update, as there are a bunch of other parts that have been bolted on as well!
But, as promised, here are some pics!
Goodbye, nasty, busted subframe!
Hellooo shiny new one! Well, shiny new to me anyway.
For the first time since she's arrived here, the engine bay is complete! I haven't test fired it yet, but she ran fine when I pulled her into the garage, no reason she wouldn't now.
There's still some finish work/cleanup to do, but if she had wheels she could finally sit on the ground! I did a little bit of upgrading while I was down here. It's hard to see but I added a Z06 power steering cooler, and upgraded the front spring to a Z06 spring. Eventually I'll find a matching rear spring, and hopefully some shocks as well.
Made sure that the tabs would align correctly before continuing. Fortunately this type of plastic tends to crack versus bend, so everything fits together pretty tightly
After a quick clean up the tabs were super glued back together, but i dont trust the super glue to hold it on its own.
Had some washers laying around, so i scuffed one side and used some epoxy to adhere the washer to the plastic. Going to do a test tomorrow to see if its strong enough or if i need to add some other form of reinforcement.
3M Body Panel Adhesive is some wickedly strong stuff when it cures. That would hold those tightly and then you could spray them black over the dingy white it dries to. Or some other strong epoxy would also work well behind the washers to secure them to the tabs.
I’ve used this process from making custom engine covers to repairing **** I break on the Vette. Recently, I broke a tab off the dead pedal, and welded it back together in minutes.
Still, I like your ingenuity in bonding the washers to the damaged areas.
Did some wiggle/flex testing. Part seems to be holding solidly, so back on she goes!
Originally I was planning on doing a full stock restoration on the car. But now the mod bug is biting, and I'm feeling more of a resto-mod situation is what I want.
That being said, its not much of a mod, but a friend of mine had a set of amt control arm studs laying around and donated them to me. So first mod done!
Now back to the repairs. One part of this project ive been dreading is the wheelhouses. They took a beating in the accident. The drivers side faired okay, at least none of it is missing, just super damaged. The passenger side however...
yeeaaahh that's a little worse. So my current plan is to repair the drivers side, then measure the shape. I happen to have a small cnc machine in my garage, so im going to model the shape, mirror it, cut a mold out and make a new piece to replace the missing section on the passenger side. Super involved, but cheaper than the 600+ I've seen for wheelhouses online.
Anyway, onto the drivers side repairs.
Im starting out with the outer part first. Its the most solid and will give me a good starting point. First step was to clean and sand the damaged area, then clamp it in place.
I didn't have any fiberglass, but i did have some carbon fiber scraps from an old project that fit perfectly!
And then it was a simple matter of mixing some epoxy resin, and then layering the CF on.
so now that that section is finished. The flat part that holds the brake duct in place can be fixed!
