Engine Removal
Old Aug 26, 2022 | 01:12 PM
ttiros's Avatar
ttiros
Default Engine Removal
My mechanic said if he has to replace the lifters in my 2002 C5 the engine must come out. Does this sound correct? I’m hoping it’s just a bad rocker arm.
Old Aug 26, 2022 | 01:19 PM
norcalace's Avatar
norcalace
Time to find a new mechanic. Rocker arm nor lifter replacement require engine removal.
Old Aug 26, 2022 | 01:24 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
NO !!…tell your mechanic to close his shop and sell hot dogs instead !!
Old Aug 26, 2022 | 01:31 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Sounds like this guy is trying to rip you off. Find a different mechanic as quick as you can.
Old Aug 26, 2022 | 02:45 PM
1999corvettels1's Avatar
1999corvettels1
Also what if he wants to steal his LS1 and slap a junkyard 4.8 or 5.3 back in with LS1 accessories?
Old Aug 26, 2022 | 02:46 PM
scorpiofox69's Avatar
scorpiofox69
The "top end", not the entire block. Ask him and see how he responds.
And as others said, find a non-rip off artist.
Old Aug 26, 2022 | 04:12 PM
grinder11's Avatar
grinder11
Your "mechanic" sounds like he'd have difficulty assembling a tricycle from Walmart. As him if he removes heads to change the sparkplugs!!!! If he says yes, tell him GREAT-You can change the lifters now, too!!
Old Aug 26, 2022 | 05:34 PM
PerryKing's Avatar
PerryKing
2020 C6 of the Year Finalist - Modified
Another 👍 for your mechanic being an idiot or at least not knowing anything about engines. Plenty of YouTube videos out there you can watch to learn the process for yourself so you can call him out on his BS.
To Engine Removal
