Control arm and steering rack bushings….
Old Sep 5, 2022 | 01:05 PM
molardog's Avatar
molardog
Default Control arm and steering rack bushings….
Hey guys just wondering what kind of typical age/mileage every one has gotten out if their original parts? I have a 99’ with 52k miles and am wanting to make the handling feel tighter at highway speeds. Car currently has that “70 feels 100mph” feel going on and am wondering how much if any the rubber suspension parts may be playing a role. Could they be “tired” and contributing to the issue? They do appear to be dry and gray colored but not splits/cracks or shifting. (Car rides on OEM magnesium wheels with new Continental tires. Tie rods are brand new and ball joints seem fine.)
Thanks in advance!
Old Sep 6, 2022 | 07:31 AM
JCMDoug's Avatar
JCMDoug
I had the same sort of feeling so I changed my shocks form tired FE1 to new Sachs shocks when they showed up they also had a TRW sticker on them.
Long story short the ride is much better and over 100 feels stable with no loss in ride quality.
If I did it again I would get C6 ZO6 shocks and may do so in the spring.
Old Sep 6, 2022 | 06:13 PM
molardog's Avatar
molardog
I did recently put base c6 shocks in. Overall feels great but am just looking for that factory new handling feel.
Old Sep 7, 2022 | 06:37 AM
JCMDoug's Avatar
JCMDoug
The bushing all look good, it won't hurt to change them out they have to be a bit tired, I was thinking maybe the spring rate or bigger sway bars.
How are the sway bar bushings.
I need to find someone with the Z51 package so I can compare how it feels compared to the FE1 setup.
Old Sep 8, 2022 | 08:22 AM
smitty2919's Avatar
smitty2919
Some of those bushings are pushing out and now 20+ years old. AFAIK, there are no OEM rubber replacement bushings. You may be able to buy control arms with rubber in them but they may be $$$ and hard to find. Otherwise people go poly as a cheaper alternative to delrin bushings.
If your goal is factory OEM ride...adding poly or delrin bushings will firm up the feel going over sharp bumps so you may not like it.
I'd also suggest evaluating all of your ball joints as well.
Old Sep 8, 2022 | 10:32 AM
6speedsteve's Avatar
6speedsteve
Can get Delrin or Aluminum steering rack bushings, maybe also change out your front shock bushings for Poly, I did both when I installed my coilovers, can't really say if the steering rack bushing made any difference, but the shock bushings are nice because they don't compress like the stock rubber does.
https://www.dougrippie.com/c5-suspension
Old Sep 8, 2022 | 10:57 AM
6speedsteve
Complete control arms are available from Dorman, Mevotech, 3 options listed on the Dorman site.
https://www.dormanproducts.com/gsear...ontrol%2520Arm
Old Sep 8, 2022 | 11:16 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
The bushings are old, but they don't look bad enough that they would be causing your issue. I would have guessed shocks as well, but it seems like you switched those out already. What do the end links on your sway bars look like? Since you have a '99, you would have the crappy plastic ones. I would look at replacing your end links with metal end links. You could swap out for better sway bars while you're at it. You might also want to make sure that you have a good alignment along with road force balanced tires. Can you go into more detail about your issues with the ride at high speed? My car is rock solid at 100mph+ so I'm not sure exactly what you mean by "70 feels 100mph".
Old Sep 9, 2022 | 08:23 AM
smitty2919's Avatar
smitty2919
Interesting. Sucks to have to buy a whole arm JUST to get new bushings. Rubber bushings (if they were serviceable) would have been maybe $30 per arm lol. One UCA from Autozone is $160.
OP you could buy all new arms/bushings then sell your old ones to someone doing a poly/delrin bushing swap.
To Control arm and steering rack bushings….
