Windshield- repair or risk it
Anyone have any experience with a windshield replacement going well and reusing the trim?
I've got a series of chips. And even though new glass would be preferable. What happens if the trim cannot be salvaged?
St. Jude Donor '21-'22
I had a major crack in my winshield, and had no choice. I used a local glass shop that my body shop works with. It turned out really well. With that said, if all you have is chips, I would hold off. Supposedly Corvette Rubber will have a replacement part "soon". Good luck.
I'm so reluctant to take on this replacement job... You know, reuse the old sealing gasket.. GM's give a damn attitude towards replacing the cracked windshield of their product with new parts has me reluctant to attempt the fix. .... I don't like a whistling, leaking windshield while driving ...so is a NEW seal required?.. No GM seal available... I'll just drive around with it cracked?..guess so.. Mary's GM answer.. We at GM don't care.
I recently got a rock chip in my windshield (Z06). I knew that that might be a hard to find item ( glass and seals), so I has Safelite repair right away, can even see it unless you look really hard. Get the chips fixed, you might not have a perfect windshield anymore, but all the seals will be intact.
I've got a series of chips, and even though new glass would be preferable, what happens if the trim cannot be salvaged and I need to consider UTV accessories for proper replacement?
