Hello, i replaced my steering wheel with an aftermarket quick release, I can not find anything that says how tight i should have the bolt when i put the hub back onto the column.
If anybody can show me where to find it or what those specifications are that would be great.
I have a 2002 base model and putting a nrg quick release if that helps.
Thanks,
Corbin
Are you referring to the steering wheel shaft nut? 30ft/lbs, I think *technically* spec is 27ft/lbs.
