Targa top head trim sagging
Old Oct 22, 2022 | 03:02 PM
Dnacc5's Avatar
Dnacc5
Default Targa top head trim sagging
Noticed the plastic trim piece near where the targa top pins attach is sagging and cannot figure out the fix. The pine tree pin seems to be in all the way but the trim piece still hangs down. Any ideas?
Old Oct 24, 2022 | 12:05 AM
jdewolf's Avatar
jdewolf
I haven't pulled that piece of trim off before, but simplest thing would to pull it off and inspect. I'd suspect it's a the plug.
Old May 17, 2025 | 05:21 PM
KStewy808's Avatar
KStewy808
3rd Gear
I know this is a relatively old topic, but I had just purchased a C5 this week and noticed the same issue on the driver side only. Plan on taking it off when I get home from work and seeing if the "Christmas tree" clips are the issue or not. Luckily, it seems like this halo trim is reasonably priced online in case I mess it up.
Old May 17, 2025 | 10:42 PM
Good luck - hope the fix is a simple one.
To Targa top head trim sagging
