thoughts on this
Old Oct 22, 2022 | 09:22 PM
walleyejack's Avatar
walleyejack
Default thoughts on this
am not understanding how this could happen, the ring gear looks like new, yet 4 teeth destroyed on the pinion. 3.90 ration in a rpm built diff. No track days no auto cross. c5 z06
just started with a nasty vibration and had it towed in to the shop.
Any thought on this, i m curious what the lads think
Old Oct 23, 2022 | 12:16 AM
jim993's Avatar
jim993
Clear evidence of a fatigue crack in the lower tooth, upper tooth failed in overload as a result. Look for a "beach" pattern ( ever expanding discolorations) to indicate a fatigue failure in the lower tooth. Probably a flaw in the lower tooth-- slight crack or stress riser where the "beach" pattern started.
Early hot rodders polished connecting rods to eliminate surface imperfections that might constitute stress risers that would precipitate a beginning crack and ultimate fatigue failure.
Old Oct 23, 2022 | 08:04 AM
walleyejack
unteresting, i did look, but will examine closer.
these gears been in for approximately 18ys.
Old Oct 23, 2022 | 12:49 PM
vette4fl's Avatar
vette4fl
Warranty should be fine.
Old Oct 23, 2022 | 01:34 PM
walleyejack
Old Oct 28, 2022 | 07:13 AM
wydopnthrtl's Avatar
wydopnthrtl
I agree... poor quality in manufacturing is most likely the cause.
Old Oct 29, 2022 | 03:44 PM
Looks like a defective pinion gear to me.
To thoughts on this
