[Z06] Tire Fitment
Old Oct 25, 2022 | 08:58 PM
GSPORT96's Avatar
GSPORT96
Default Tire Fitment
What is the largest size tire anyone has put on the rear of a C5 rear wheel (stock wheel) ? I will have wide body fenders as far as room to work with. Any advice ?
I like my C5 wheels and really don't want to replace them. Thanks
Old Oct 27, 2022 | 07:52 PM
Beast's Avatar
Beast
Not from my experience, but from seeing what others post.
Wide tire
305 35 18 or
315 30 18
tall tire
295 40 18
Good Luck.
Old Oct 28, 2022 | 07:07 AM
wydopnthrtl's Avatar
wydopnthrtl
I upsized +1 and like it for just avg use. https://www.corvetteforum.com/forums...xperience.html
Old Oct 28, 2022 | 07:26 AM
raycer's Avatar
raycer
I need tires. I was thinking 295/35 18 and 275/40 17 but Continental Extremecontact have supply issues. I might do what you did. Looks good. Only problem is that's an inch taller in the back. How is the speedo error?
Old Nov 18, 2022 | 04:22 AM
Boss 57's Avatar
Boss 57
Get them widened. Or get another set and get them widened. Narrow wheels and widebody do not mix well.
I've done this with GTO factory wheels, look worked and performed great. Contact Weldcraft, they do this all the time.
However personally I'd spring for a set of light wider wheels, for exponential weight savings, and proper wider tire fitment (don't skimp).
EDIT
I just noticed 'Z06' in the thread title. Those are 10.5" wide (w/295 stock).....however same theory holds.
Old Nov 18, 2022 | 09:56 AM
ssmuff's Avatar
ssmuff
2021 C5 of the Year Finalist - Unmodified
You could look at the Nitto NT555 G2 for the front 275/40r17 and the Nitto NT555II for the rear 305/35r18. Nitto's website say they are designed to go together as a front/rear combo.
Old Nov 18, 2022 | 03:41 PM
FourG63 97GST's Avatar
FourG63 97GST
The limitation is the wheel width. I'll assume you're talking the base C5 9.5" wheel. 285 is technically the widest, maybe a 295 but that's pushing it.
you really shouldn't do widebody if you don't want to do wheels. it looks unfinished, and not thought out. especially if you're not taking the advantage by getting more tire.
To Tire Fitment
