2000 ecbm help
Old Nov 24, 2022 | 10:07 AM
jimbo409's Avatar
jimbo409
Default 2000 ecbm help
I am thinking of buying a 2000 vette but have heard not to buy this year because of the ecbm issue, I watched utube abd they said no one sels this part and no one repairs it so what do you do . i cant believe that the car turns into a boat anchr, please help the car has 37000 miles
Popular Reply
Nov 24, 2022, 12:31 PM
norcalace's Avatar
norcalace
EBCM failure does not kill the car. It kills the anti-lock braking function. 33k C5s were built in 2000. I would think if failures were as prevalent as some would have you believe there would have been a recall early on. Anyway, if it fails you can either live without anti-lock brakes, buy a used unit and hope it works or adapt a later model unit to your car. I have a 2000 with 66K on the clock and if mine fails I’ll drive on and never miss it.
Old Nov 24, 2022 | 12:31 PM
norcalace's Avatar
norcalace
Old Nov 24, 2022 | 12:44 PM
2010Pony's Avatar
2010Pony
I also have a 2000 with 73,000 miles on it. No problems so far but if it goes out I’ll keep driving they didn’t have the anti locks on the old cars and I very rarely drive in the rain anyway. My only issue is that damm gas gauge dropping to zero problem and I just learned to live with it. If you like the car go for it
Old Nov 24, 2022 | 03:06 PM
DWAVette's Avatar
DWAVette
I recall when ABS was being introduced to common vehicles in the late 80s/90’s. I had been driving 60’s and 70’s trucks and cars since I was 13 and swore there was NO way I would ever trust a damn computer control my brakes!!! Now, we talk about not even buying a car where there is a small percentage chance the ABS system might fail.
After putting those thoughts in perspective, I purchased my 99 Vert about two years ago.
Old Nov 24, 2022 | 03:42 PM
2010Pony's Avatar
2010Pony
I agree with you DWAVette 100%. At least I looks like your in a warmer part of the country and you can still drive yours, I put mine to bed November 1.
Old Nov 24, 2022 | 05:48 PM
wrmiles's Avatar
wrmiles
Do without it. My 2002 ECBM has been inop for a long time, fixed once, available but too expensive for an unreliable part.
Old Nov 24, 2022 | 07:32 PM
knewblewkorvette's Avatar
knewblewkorvette
Don't let the ECBM possible failure scare you. It does not make the car a "boat anchr".
Also, in my experience, the older ECBMs seem to be more reliable. I've had a 1998, two 1999s (still own), a 2000, and a 2002 (still own) in the past 21 year. In those 21 years, I've had one ECBM failure and it was on the 2002.
Old Nov 24, 2022 | 09:35 PM
grinder11's Avatar
grinder11
Yup!! Drove 25 years before my first ABS vehicle. Didn't miss it then, wouldn't miss it now. Too many things in this modern world that we "can't live without!!" Active handling is another. Sure, they're great......when they work. I'll be damned if not having either will take my car off the road. If you live in a state that has inspections, remove the MILs. There are ways around the fools in government who "think" they're "protecting us."
Old Nov 25, 2022 | 08:09 PM
jimbo409's Avatar
jimbo409
What is the mils
Old Nov 25, 2022 | 08:40 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Originally Posted by jimbo409
What is the mils
Malfunction indicator light.
Old Nov 25, 2022 | 09:20 PM
norcalace's Avatar
norcalace
I was born in the fifties and learned early on how to “pump” the brakes. However I’m thankful for those “fools in government” every time my children and grandchildren get into a post 1990 passenger car.
Old Nov 26, 2022 | 02:44 AM
Good advice.
Old Nov 26, 2022 | 07:46 AM
2010Pony's Avatar
2010Pony
How do you get rid of the light without removing the bulb and how hard would it be to do that ?
Old Nov 26, 2022 | 11:52 AM
Dads2kconvertible's Avatar
Dads2kconvertible
You could design an interface to the module and write software, then flash the new software you wrote that doesn't turn on the light when there is an issue.
Much, much easier to remove the bulb if it's bothering you.
There really is no reason not to simply live with the reminder your anti-lock braking and traction control functions are inoperative.
Old Nov 26, 2022 | 12:39 PM
knewblewkorvette
I came across this on a C5 group on Facebook. I have absolutely no feedback on this product but it seems like an option for those whom have a bad EBCM and wants to get rid of the lights. It sure isn't cheap though at $200. Still, it beats what they are asking for a used EBCM on eBay though, those prices hover around $1,800
For track use only
https://www.revolutionelectronics.co...-corvette-abs/
Old Nov 26, 2022 | 05:21 PM
killain's Avatar
killain
Oldtimer
Well my 2003 is currently having an issue with it's ABS, but the car runs fine, if you don't track the car you could almost forget about the ABS if not for the dash light ?
Old Nov 27, 2022 | 11:03 AM
2010Pony's Avatar
2010Pony
How much much work would it be to remove the bulb, I did that on my 88 and wasn’t a hard job but not sure where to start on my 2000 and can not find any information on it.
Old Nov 27, 2022 | 03:12 PM
rrwirsi's Avatar
rrwirsi
If you drive in the winter where ice and snow occurs, having ABS can save you and the car. My first ABS car was a 72 Acura Legend. I entered a limited access road and hit a patch of ice/snow on the road and the car did a 180 heading for the ditch. I slammed on the brakes and by doing so the ABS straighten the car out and avoided an unpleasant result.
Old Nov 27, 2022 | 03:45 PM
schmuckingham's Avatar
schmuckingham
My 2000 Vert has 52k miles on it. It sat for 7 years before I bought it and had awful fluid in it while I drove it for a few months and it has never given me issues.
To 2000 ecbm help
