No More Emissions!
Four more years before the Z06 likewise passes the same hurdle. Think she'll pass the sniffer with a 402, PRCs, Jam Cam and 14psi? I'm certain she will.
In Ohio I was able to apply for a "Collector" plate, different from a historical plate which is based on age, that means I no longer need to do emissions testing. It was only like $10 more per year than regular plates.
I hate emissions testing.... Only a few counties in Ohio still do it.
Then they put cameras in and that option ended which was smart on the part of the state until they then "got with the times" so the modern emissions test consists solely of plugging into the OBD2 to read if all the tests in the ECU have been checked off and to verify you don't have a check engine light. And let me tell you...... that is SOOOO much easier to pass now. You don't even need to disable the tests to pass so you can stay legal with it even from a tuner's perspective.
Two reasons. The main one is emissions testing did it's job and forced not only better technology, but also forced people to get used to driving newer more modern cars over the last 25 years. Therefore it is very rare for anyone to be driving around in what is considered a gross polluter anymore.
The second reason is that it was run by an out of state third party contractor that was just raking in the money for themselves and doing nothing but COSTING the state money. Brilliant.
Kind of shocking for a pure blue utopia state that has become the new Nor Cal to do away with it.
To the states credit, when OBDII came out it turned into a run what you brung as long as it passes scenario. No visuals. Just had to have all but one rediness monitor set, of course no check engine light and you passed. So in other words you could have a pretty heavily modified car and still pass emissions. It was kind of a hot rodders dream.
OBDI was much more of a pain in the ***.
I went the Collector plate route in Ohio as well so I could avoid the last couple of E-Checks on my '99 FRC and the '90 RX7 before that - no way in Hell that car would have pasted the tail pipe sniffer test!
The Collector plate is for special vehicles. All Corvettes are on the list, but if you have a car not on the list you have to show $5000 worth of mods to make it special and then they MAY approve your application.
Yeah, lots of ratty cars, no inspections, hurricanes...
Better to stay in Pa. Pass the word.
