Brake upgrades...6 piston
I only used that brake set up because it was handy, I have a set of C7 Z51`s I will also mock up with, they use a 2 inch hat depth rotor where these ZL-1`s use a 2.40 hat so that .390 actual difference (10mm) has to either be stand offs or thicker bracket buried into the casting. I guess the goal is to have a reasonable cost brake that has a functioning park brake for the C5 and C6 base cars. So with this set up if it ever comes to fruition would hold
- 2009-15 CTS-V stock rotor w/ center hole opened to 2.78
- 2016+ CTS-V (same as 6th gen ZL-1`s)
- 2010-15 Camaro SS w/ stock rotor pilot opened & 2013-15 ZL-1 stock rotor w/ center hole opened to 2.78 Or use Z06 C7 front rotor
- 2016-current Camaro SS w/ C7 z51 rotor ZL-1 w/ rotor pilots opened, 14.6 1LE with rotor pilot opened
- 2014-19 C7 Corvette JL9,J55,J56,J57 so all your C7 brakes
- 2020 C8 JL9 and Z51 (fronts)
- XTS and ATS Brembo Cadillac w/ appropriate C7 rotor
Here is the stock C6 knuckle- with the sample bracket Thank you Norcal auto in Rancho Cordova
You now have my attention.
It’s nice to see visual of the geometry and how it all lines up.
Firstly - grinding or cutting isn't hard to do, provided someone has access to a grinder and a flappy paddle.
Second - most of those interested in the brake conversion are going to be the doer and wrench spinner type who will get it done.
I've already ground mine slightly for the mini mantis kit. And I've already got a fresh set of C6 Z06 brakes ready to go on the car. But who is to say I don't sell those and go with a better Brembo kit before the car comes off the lift soon? Seems very doable.
Does need abuse testing though and I like the hills MC556 (should be MC762, imo) was showing, but I'm old school and prefer the heavier round.
...and that is either having the bracket cut with a hex shaped hole to accept a M12 bolt head and welding in place then drilling the hub bearing mount hole to pass a M12 stud through enough to use a nut on it to secure the bearing / bracket to the knuckle. I`ve looked at the bearing and a std height nut would be close, a shorter M12 jam nut would fit easier, obviously a stover or all metal lock nut would be ideal. the surface the nut would be on is flat on the stock bearing that I have, not machined but flat at least
Or threading the lower bracket using a double end stud..again welding the stud and bracket as one
The only way I can visualize a standard fastener type down there is going to a 3/8 bracket dropping that in as far as needed and then using a flat head cap screw countersinking it into the steel as far as possible, up to flush at most of course. I do this on one of my other brackets on a 3/8 thick bracket
the rear ones to be exact. The conversion brackets although not dead yet are starting to look less inciting, we do not want to mill the spindle of any base material of course and bolt on is a no go so some work or clearing has to happen but the lower bearing mount is a issue. I thought I had it with the park brake figured out but that lower mount is a problem. It was smart to keep that hub and basically that inclination angle close to the joints but bad for making things fit that should not. While those go back burner for the moment- I picked up a set of rear C7 knuckles and loaded the pics into some cad software, while the the dimension lines like somewhat sketch, they were taken off of direct measurements and transferred to basically pictures so round the small numbers..to the closest common value (i.e. 4.011 = 4.0 inch)- again I played with the dimension lines to get the actual measurements close..pics converted to cad do not measure exact as you would think lol..
The knuckles are fairly close, these pics are misleading somewhat, they are scaled to be the same size so look at the numbers !
the lower ball joints are the same, the uppers are the same, the toe link is out some and its taper diameter is smaller. the C7 does have 1 inch more height, the lower ball joint center location as measured from the hub flange is shorter or closer by about .187 vs the C5 / C6. The C7 bearing location will lower the C5 / C6 by .125, upper ball joint center to hub flange is the same distance.
So we are bringing the lower part of the spindle in by almost 3/16 raising the upper ball joint an inch (18`s minimum) and the toe link is lower by 1/2 inch and further out from center by .75 of an inch...
whats your thoughts? I know there is another thread it was done but not on a corvette, a transplant into a Jeep where you can probably make up differences with some fab work. Opening the toe link taper will get them on, not sure what if any the higher ball joint will make a difference in align ability besides needing a 18 inch wheel at least...the lower ball joint hole on the C7 being .187 closer to the bearing mount is going to create positive camber if that raised ball joint doesn't pull the top of the knuckle in the same amount.on a C6.
