PCV Valve (boot?)
Old Jan 2, 2023 | 01:56 PM
Aggie0954's Avatar
Aggie0954
Cruising
Default PCV Valve (boot?)
Been on the hunt for why my engine bay is dirty with oil residue. Think I found the culprit…one of the culprits at least. My attachment/boot? to my PCV valve is cracked. What is this attachment called and where can I get a new one?
Old Jan 4, 2023 | 02:35 AM
If your dealer cannot get you a new one, try a vendor like VetteNuts and see if they have a good used one.
Old Jan 4, 2023 | 08:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
How about just using some fuel line ??
Old Jan 4, 2023 | 11:44 AM
Smoken1's Avatar
Smoken1
https://www.rockauto.com/en/parts/ac...on)+hose,11784
This is for the Z06
Old Jan 6, 2023 | 12:21 AM
Aggie0954's Avatar
Aggie0954
Cruising
I actually just picked up a piece of fuel line and clamps. Gonna give it a try. It should work I would think.
Old Jan 6, 2023 | 12:24 AM
Aggie0954's Avatar
Aggie0954
Cruising
Originally Posted by Smoken1
thanks for the link. I had seen that too. Just didn’t want to pay $80 for the whole thing when all I need is a small piece. Ended up spending $7 by purchasing fuel line and clamps at AutoZone.
Old Jan 6, 2023 | 12:37 AM
C5 Diag's Avatar
C5 Diag
That’s how I repaired a Forum members car last year that was showing some lean codes…worked fine !!
Old Feb 12, 2024 | 10:25 AM
joekd's Avatar
joekd
Had air shocks on my first car years and years ago, needed them to fit the L60 tires under the rear (if you understand what those are you also are too damn old just like me)
Old Feb 12, 2024 | 10:58 AM
bookyoh's Avatar
bookyoh
I know this thread is over a year old.
Here is a Dorman part some members have said will fit.
To PCV Valve (boot?)
