[Z06] Cold temps and the Z
Old Jan 11, 2003 | 02:53 PM
jwight's Avatar
jwight
Cruise-In I Veteran
Cruise-In II Veteran
St. Jude Donor '08-'09-'10
Default Cold temps and the Z
It's in the mid 20s here in SW Ohio today - sunny and clear. The car absolutely loves it!
Had it out this afternoon and the rear tires start breaking loose with a normal launch from a standstill; no WOT, just a nice push on the pedal and the rear tires start giving it up. And the Blackwing's not even on yet! This is too :cool:
Old Jan 11, 2003 | 03:01 PM
Gaijin's Avatar
Gaijin
Cruise-In I Veteran
Cruise-In III Veteran
Default Re: Cold temps and the Z (jwight)
Just be mindful that traction is very minimal due to the cold roadways. Otherwise, yes....they're great with the dense, cold air. More ponies!
:yesnod:
Old Jan 12, 2003 | 09:35 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Cold temps and the Z (Gaijin)
:yesnod:
:iagree: Very minimal traction with the F1 tires when it's cold out.
Old Jan 12, 2003 | 11:44 AM
Tracy's Avatar
Tracy
Default Re: Cold temps and the Z (Z06ufgrad2002)
Yep, it all sounds very familiar.
Motor's breathing cold air and making strong torque, and with the cold tires makes for some tail-out "momments".
Be careful out there!
Old Jan 12, 2003 | 08:29 PM
bully's Avatar
bully
Sounds very familiar, the car just loves the cold temp, If only I could say the same about the tires, I all over the place. :banghead: :iagree:
Old Jan 14, 2003 | 12:34 PM
dbvettez06's Avatar
dbvettez06
Try driving the Z with a blower! Temp was around 10% today, clean roads it was a blast, impossible to get into boost without obliterating the tires... :cheers:
Old Jan 16, 2003 | 02:11 AM
SMFCPACFP's Avatar
SMFCPACFP
It was around zero here today, but I doubt if i could get the Z to move.
Old Jan 16, 2003 | 05:52 AM
vette6799's Avatar
vette6799
St. Jude 15 Year Donor
St. Jude Donor '11 thru '26
Default Re: Cold temps and the Z (Tracy)
I first started noticing the dropoff in traction in October as the temperatures started dropping. I wonder what the braking distance rises to as temperatures start gping well below freezing.
Old Jan 16, 2003 | 08:12 PM
BlazeSkywalker7's Avatar
BlazeSkywalker7
I am having the same problem
if i give it any throttle in 1st or 2nd gear i loose the back end
3rd is a little better but i still cant put the peddle to the floor
so bring on the warm weather!!!!!!!!!!
aahhh the joys of 405+ hp
-Rich
To Cold temps and the Z
