Motor Replacement
Old Feb 6, 2023 | 01:47 AM
lspowah's Avatar
lspowah
Default Motor Replacement
Weighing out my options replacing/rebuilding.
02 z51 with 110k.. has new balancer, new upper and lower oil.. new o ring in oil pump.. full catback exhaust, cai.. new pads and tie rods, new f14 wheels new continentals.. just some of the things I done to her.. lifters probably need replaced, tapping like crazy now. Thought it was piston slap, maybe it is but it’s gotten way worse. Doesn’t fully go away when warm anymore, matches rpm too. Did a flush, different oils etc.. But runs like a champ, no oil pressure issues or metal shavings in oil. Everything looks solid. But she’s tappin away.
considering rebuilding the original motor, dropping a fresh ls1, or dropping in an ls3. Including cam, heads.. Would be hiring a friend to do it as I don’t have the ability to myself. I can work on her but doing all of that correctly, I’d prefer he does it. Just lookin for some opinions regarding best move to make/cost etc
Old Feb 6, 2023 | 08:36 AM
smitty2919's Avatar
smitty2919
Cheapest would be a simple rebuild but I'd add a cam at least.
Upgrade would be a rebuild with heads/cam.
Most fun would be LS3 with heads/cam.
You Pick.
Old Feb 6, 2023 | 08:49 AM
JMG2's Avatar
JMG2
Moderator
sounds like the motor was taken care of, a rebuild would be easiest, cheapest, and least amount of heartache.
If you're going to drop a new motor in it, it's not that much more work to do a ls3. But I'd just do a rebuild.
Old Feb 6, 2023 | 10:37 AM
Johnny Hardcore's Avatar
Johnny Hardcore
If you plan to hold on to the car...rebuild it, do heads and cam and go with forged internals for just a few hundred more $$$. Then when you get bored with that supercharge it. Forging it will let yiu worry less about it coming apart prematurely under boost.
That's what I did and I could not be happier. I also plan to keep this car until I'm unable to legally drive. I'm 48 so it should be a long while.
Old Feb 6, 2023 | 12:45 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I think the best option would be a rebuild. That will be both the cheapest and easiest. It will give you a nice reliable car. Regardless of if you swap out for forged internals, you can always add an A&A kit for more power. I certainly love mine.
Old Feb 6, 2023 | 12:50 PM
acroy's Avatar
acroy
do a little moar troubleshooting before assuming it's new engine time. Pop off the valve covers and see what's to be seen.
I agree though, rebuild with a few inexpensive upgrades would be a reasonable option.
Old Feb 6, 2023 | 02:47 PM
CinciZ06's Avatar
CinciZ06
I just completely rebuilt my LS6 after my lifters ate the cam and disintegrated a lifter body in the process - valve float was my enemy. I had the block machined (10 over), rods resized, and added forged pistons with rings gapped for nitrous.
All in, after parts (including new cam / lifters, gaskets, bearings, etc) and machine work ($1500), I am at about $3900 in total. I spent about 15 hours blue printing and building the block, and likely just as many putting the motor back in. I work slow and triple check everything along the way so many likely do it much faster. If I were paying someone to build the motor, it would have been cheaper with buying a crate motor. However, with rebuilding your LS1, you have total control on parts selection and retain the aluminum block. Piston selection is currently limited, but icon and manley both sell pistons in appropriate bore sizes.
Your bottom end may be completely fine however. And simply rebuilding your top end could be the best time and money spent. Good luck and enjoy the process - it's a ton of fun.
Old Feb 6, 2023 | 04:33 PM
vette4fl's Avatar
vette4fl
Absolutely need to look into this further. Perhaps do a leak down to see where the ring and valve wear is. If those look ok, why tear the whole engine down?
If it’s just lifters slap some new ones in, add some new springs/HD pushrods and done.
If the cam is done, great time to spec the cam you want, lifters/springs, new heavy duty pushrods, a timing chain (and maybe Melling M295 oil pump).
This is stuff that can be done in a couple of days.
Pro tip: Use the thousands you’ll save and head to Aruba for a few days while the work gets done.
Old Feb 6, 2023 | 06:17 PM
Johnny Hardcore
Good advice above until the Aruba reccomendation.
If you fly that direction Riviera Maya/ Tulum, Guatamala, Costa Rica, heck even Puerto Rico are all better travel destinations than Aruba.
Old Feb 6, 2023 | 07:27 PM
lspowah's Avatar
lspowah
that’s the most sensible thing to do for sure bud. I agree. I had it down to the rocker arms and everything checked out looked fine. The tap is driving me up the wall. I don’t have the ability to take it all the way down right now. Until I move later this year. I don’t have a garage but a makeshift carport I put up in the meantime, and live on dusty roads. My buddy said he would do a fresh rebuild ls1, cams, headers, tune, for about 6. Only thing is he lives 10 hours away. I’d like to learn to work on it myself in that depth for sure. Just not an option until later this year and the tapping makes me want to rip my hair out lol
Old Feb 7, 2023 | 01:38 AM
vette4fl's Avatar
vette4fl
Can you just put it on a car hauler to your buddy?
Maybe rent a Kia 😂 for a week…
Old Feb 7, 2023 | 01:40 AM
lspowah's Avatar
lspowah
Lmao man I got a pickup.. wouldn’t daily the vette. I make a living with my f150
Old Feb 7, 2023 | 02:46 AM
Kingtal0n's Avatar
Kingtal0n
Find problem before commit rebuild. Otherwise, ton of new parts, same problem same noise
Old Feb 17, 2023 | 02:19 AM
lspowah's Avatar
lspowah
i think in order to actually find out what the noise is, the motor will have to be broken down.. might as well rebuild at that point anyway
Old Feb 17, 2023 | 10:53 AM
Fastman70's Avatar
Fastman70
There's a member on this forum who's selling brand new LS6 engines for 3200. That's a bargain.
Old Feb 17, 2023 | 11:25 AM
grinder11's Avatar
grinder11
Sorry, but good advice again......Until the Kia sentence!!! Just jerking your chain!!
Old Feb 17, 2023 | 11:28 AM
grinder11's Avatar
grinder11
REALLY?? That's a damn good price for a long block OR short block. Have a link or member name? Thx
To Motor Replacement
Old Feb 17, 2023 | 11:33 AM
Fastman70's Avatar
Fastman70
Oooops. My bad. That was a old thread that's being taken down. Sorry.
Old Feb 17, 2023 | 12:20 PM
grinder11's Avatar
grinder11
I hate when that happens!
Old Feb 17, 2023 | 10:38 PM
As stated above, a rebuild would be the least expensive way to go and you can spec out what you want in the motor. Good luck - hope it all works out.
