Rear Emlem
Old Feb 21, 2023 | 01:07 PM
AJ Powers's Avatar
AJ Powers
Default Rear Emblem
Is or has anyone else's rear emblem started to fray ??
Old Feb 21, 2023 | 01:32 PM
yellow2007's Avatar
yellow2007
I've seen them cracked and faded but never like yours. Almost looks like a chemical caused issue.
Old Feb 21, 2023 | 01:56 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
If the car sits out in a warm and sunny climate, I could see the emblem getting bad over time, but not like that. I also think it looks like some kind of chemical reaction.
OEM or aftermarket emblems are available. If you want to install a new one, I suggest taping a box around the current emblem with blue painter's tape before you remove it so that you know where to re-install the new emblem by simply aligning the tips within the edges of the painter's tape.
Old Feb 21, 2023 | 02:07 PM
AJ Powers's Avatar
AJ Powers
Is it just glued on ??
Old Feb 21, 2023 | 04:10 PM
T-RAY1978's Avatar
T-RAY1978
It's just double sided tape, you can use fishing line to remove it
Old Feb 21, 2023 | 04:34 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
Mine did the exact same thing. Just the back one. Got a new one, used fishing line. Very easy.
Old Feb 21, 2023 | 04:46 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree with everything above. In addition to fishing line, you may want to use a hair dryer to warm up the adhesive first. It should come off easily. The painters tape trick above is a great idea. The front emblem has studs that fit into holes in the hood. However, there are no studs on the rear emblem. As such, it is important to mark the location BEFORE you remove the old one.
Old Feb 21, 2023 | 05:28 PM
Vette-kid's Avatar
Vette-kid
Mine did that too. Sits in a garage, no chemical spill. I refuse to pay OEM prices for replacements given the poor quality of the original. $25 on Amazon. Easy to replace.
Old Feb 21, 2023 | 10:16 PM
vette4fl's Avatar
vette4fl
I just bought one from VetteNutts for about $22. Excellent part.
https://vettenuts.net/97-04-c5-corve...em-gm-19207385
Old Feb 21, 2023 | 10:23 PM
vette4fl's Avatar
vette4fl
In addition to warming it up (just touch with your finger while warming it to check. You don’t want it hot, just warm), you can also use dental floss, and if you have plastic trim removal tools those can be used gingerly once you have a corner lifted up. Once you get it started it goes quickly.
You may need to compound or cleaner to get all the remnants removed.
Old Feb 22, 2023 | 03:09 PM
Stroker_9's Avatar
Stroker_9
Looks better with it off in my opinion. Mine is removed.
Old Feb 22, 2023 | 03:29 PM
c5arlen's Avatar
c5arlen
I've taken care with both of em.... They are perfect and twenty years old, shiny and intact. Clean em with a tooth brush, brushed lightly... One must treat them with reverence as General Motors, knowing them, will surely discontinue keeping them around and giggle 😂 when customers ask for a replacement of the pesty little cheap *** sucker.
Old Feb 22, 2023 | 03:36 PM
AJ Powers's Avatar
AJ Powers
Thanks for the help and input folks. I ordered one, but am contemplating leaving it off now if the area cleans up well.
Old Feb 22, 2023 | 03:55 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Mine looked even worse than that, it was actually missing pieces as well as the front one. I replaced the front and left the back off, I also prefer it without. If the front didn't have locating holes in the fascia I would leave it off as well.
Old Feb 22, 2023 | 04:43 PM
WDEagle's Avatar
WDEagle
My front & rear emblems did exactly like yours OP. My car is 99% garage kept. Ordered a replacements and my son replaced them for me.
Old Feb 22, 2023 | 04:53 PM
vette4fl's Avatar
vette4fl
I love them. Perhaps the coolest emblem ever.
Still, I have a soft spot for my first set of Corvette flags…
Old Feb 23, 2023 | 07:18 AM
Not difficult to do when adding a little heat from a hair dryer to soften the tape.
Old Feb 23, 2023 | 07:33 AM
sonicss33's Avatar
sonicss33
I took mine off as well but have decided to put it back on. Reason being, I can’t stand leaving fingerprints every time I close the trunk. I don’t tend to wear white gloves or carry a towel in my pocket to wipe them off.
Old Feb 24, 2023 | 09:25 AM
rrwirsi's Avatar
rrwirsi
Corvette OCD?
To Rear Emlem
