Brake rotors
Old Mar 3, 2023 | 04:52 PM
Komiller118's Avatar
Komiller118
Default Brake rotors
Did GM offer slotted rotors on any base models? My new to me has drilled and slotted rotors all around? I did not see anything in the rpo codes that stood out.
Old Mar 3, 2023 | 04:55 PM
jackthelad's Avatar
jackthelad
They are aftermarket, C5 rotors were all solid from the factory.
Old Mar 3, 2023 | 04:56 PM
Beast's Avatar
Beast
I don’t think so. I plan on going back to plain rotors and a good set of pads for HPDE’s, Motul 600 BF, and adding some stainless steel brake lines to the calipers. Hopefully soon.
knewblewkorvette's Avatar
knewblewkorvette
Old Mar 3, 2023 | 05:12 PM
Komiller118
Do you not like the slotted rotors? I will also add braided brake lines in the future.
Old Mar 4, 2023 | 12:29 AM
No, GM did not offer slotted//drilled rotors on any C5.
Old Mar 4, 2023 | 08:07 AM
Beast's Avatar
Beast
plain rotors work fine and are cheaper. Tire rack has front rotors for 66 a piece and rears for 50 a piece. If you find slotted rotors cheaper then that, let me know.
Old Mar 4, 2023 | 08:41 AM
Fcar 98's Avatar
Fcar 98
The stock rotors were terrible. If you put any pressure at all to that rotor they will not hold up. If you drive the vette like a sports car. I would look into a quality rotor. There are plenty of good options.
Old Mar 4, 2023 | 10:34 AM
Komiller118
My new to me C5 already has drilled and slotted rotors......
Old Mar 4, 2023 | 11:55 AM
jackthelad's Avatar
jackthelad
The early rotors definitely had problems. I had 3 trips back under warranty to deal with front brake judder. Finally gave up and put a set of Baers on around 2000. Still in use with no issues.
Old Mar 4, 2023 | 12:42 PM
Fcar 98's Avatar
Fcar 98
I have the same ones
To Brake rotors
