Glove Box Lite
Old Mar 5, 2023 | 02:04 PM
d.moscatelli@comcast's Avatar
Default Glove Box Lite
Should the lite for the glove box active any time you open the glove box door or just when the headlights are on?
Old Mar 5, 2023 | 06:20 PM
grinder11's Avatar
grinder11
Never heard this asked before! I'd guess it is activated when the door is opened, regardless of headlight utilization. I had mine staying on even when the door was closed. When my son was a little boy, he told me that he could see a light on inside it. I didnt give him, or it, much thought.....Until my battery died when it shouldnt have!! Sure enough, I laid sideways in the seat, and the damn light was on! I had to make up a little piece of plastic and super glue the thing to the door. This made contact with the plunger sooner, and problem solved.
Old Mar 5, 2023 | 07:28 PM
BigBS's Avatar
BigBS
Should come on anytime the glove box is open/opened.
Old Mar 5, 2023 | 09:34 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Theres a pressure switch that is supposed to turn the light off when the box is closed. If it's still on when the box is closed, get a little rubber foot and stick it to the box lid so that it presses the switch sooner as the door is closed.
Also, switch it to an LED bulb to not draw much current from the battery
Old Mar 7, 2023 | 10:04 AM
rrwirsi's Avatar
rrwirsi
Or just remove the bulb. . Not much to see in this tiny glove box.
Old Mar 8, 2023 | 11:19 PM
OK, that gives me the info I was looking for . Now I have something else for me to fix. I check the plunger switch and the fuse to start with.
I'll report when I have that figured out or I have more questions.
Thanks , Denny
To Glove Box Lite
