02 Corvette automatic need radiator
Old Mar 10, 2023 | 05:50 PM
Smokenbutch's Avatar
Smokenbutch
Default 02 Corvette automatic need radiator
Hello besides Dewitt’s radiator what is a good one to get it’s a 02 with a automatic thanks
Old Mar 10, 2023 | 06:37 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Keep your GM car all GM. The radiator will bolt in, perfect fit and work with your other components as designed.
Now, if you have done a some HiPerf mods, track or race your car, Dewitts would be a solid choice for if extra cooling is required.
Old Mar 10, 2023 | 11:21 PM
jim993's Avatar
jim993
It depends on what you will do with the car.
If you are looking at DeWitts for added cooling capacity, it is a great choice. My car has had a DeWitts since 2013 and I am very happy with it ten years, 35,000 miles and 20 days on race tracks later.
If you want cheap, GM or any aftermarket is OK.
Old Mar 11, 2023 | 01:19 AM
The stock GM radiator should work just fine if your car is stock or just lightly modified.
Old Mar 11, 2023 | 10:20 AM
Supercharged111's Avatar
Supercharged111
On the street, yes. On a road course, no. OP hasn't specified his use. Stock is also fine for drag and autox for a mild car.
Old Mar 11, 2023 | 12:42 PM
Elektro's Avatar
Elektro
I put a Dewitts on. It also just drops in. You can kill three stones with one bird... water, trans, and engine oil. Putting the c6 oil line on was a bit of a puzzle tho. We have another thread in the c5 tech forum about it. You will need to trim the fan shroud among some other tasks for the oil lines.
It is twice the thickness of the original for much increased cooling capacity. But the end tanks and mounting locations for the AC and fan re unchanged. (the original is about the same thickness of the AC..)
I think a good general rule of thumb is if you aren't heating the oil much above the water temp with no oil cooler and stock radiator, there is no need for an upgrade radiator...
Old Mar 13, 2023 | 10:26 AM
grinder11's Avatar
grinder11
I've had my DeWitts in for 17 years/100,000 miles. Does exactly what it should. It is a "direct fit" radiator. If you never want to go through changing your radiator again, DeWitts is the radiator you want. Just change coolant per GM instructions, say every 4-5 years, with 5 years being the very most I'd go before changing coolant out. It's more money up front, for sure. If you don't plan on keeping the car, I'd go with the GM radiator. I've owned my car for almost 20 years now, so I'd probably be on my 3rd, or 4th radiator by now. In other words, the DeWitts has paid for itself.
Old Mar 13, 2023 | 10:48 AM
Smokenbutch
Thanks for all the replies I ended up going with the original gm radiator
To 02 Corvette automatic need radiator
