My only adds would be covering the wiring in expandable sleeving and some stainless allen head hold down bolts. Overthinking this? Lol..
Originally Posted by Mr. Black
I have been using factory GM LS3 coils for years. Supposedly there is a dwell change that should be made in the tune but I never have. Runs perfectly and no shortage of power.
The cloth stuff you mean Tesa tape? I would not use that in the engine bay, it is like yarn. I presume flammable and moisture holding. The heat version is good for engine bay but you'd be wrapping forever. There are numerous options out there for lengths of loom to get which can clean it up. If you're going to readjust the harness for length and lay thata chore, but if you're just shesthing it to clean it up you can zip the bundled sections quickly with a thicker loom, go back and do the short sections another time with thinner. But agreed, not necessary.
Would love to see some concrete evidence these actually do anything. Maybe what your replacing them with is actually inferior? Guess it would have to be some sort of dyno test back to back for actual proof?
I believe the OP was merely bringing a smoking hot price to our attention.
As far as which are better? Perhaps the question should be which coil works best with a particular ECU. Or…which coil works OK with a given ECU, and also looks cool. I vote for the latter. 👍
Correct! Never meant they were better or worse. Just that they were on sale CHEAP!!
I like the coil placement on the proform valve covers I have now, but the LS1 coil just looks bulky compared to the LS3/7 coil.
That to me looks ****, do the Proform covers come with the coil brackets? What plug wires did you use, because the ones on my stock setup coils/covers would be too short I think.
You can get mounts from Proform for both the LS1/6 style coil or the LS7 or truck style coil.
I used the Firecore truck wires which are a touch longer than the stock wires. Here
