Ugly stained coolant tanks..
Old Mar 17, 2023 | 11:42 AM
grinder11's Avatar
grinder11
Default Ugly stained coolant tanks..
Has anyone successfully cleaned the inside of their coolant tank with a mild acid? I've seen a few YT videos on it, but not specifically on a C5. I'm wondering if I should try it at all since the tank is 23 years old. It's stained on the inside from the GM sealant pills I used when I had a Darton sleeved engine in it. How about muriatic acid? Anyone?? Thanks....
Old Mar 17, 2023 | 12:13 PM
epimetheus-lee's Avatar
epimetheus-lee
I would first try a long soak with some simple green and/or diluted vinegar. These would be milder than muratic acid.
Old Mar 17, 2023 | 12:43 PM
RogerZ06's Avatar
RogerZ06
I wouldn't even bother. I would just replace it since its going to crack on the top or bottom sooner or later.
Old Mar 17, 2023 | 12:52 PM
grinder11's Avatar
grinder11
Yeah, I know muriatic acid is pretty caustic, for sure! I'm also kicking around a new tank, because at 23 years old, it's bound to be getting weaker, and any acid will make it weaker yet. I'll admit I was hoping to get some input from someone who has done it. Thanks guys.
Old Mar 17, 2023 | 01:26 PM
c5arlen's Avatar
c5arlen
Install new reservoir and report to us the difficulty in doing so. 😊👍😁
Old Mar 17, 2023 | 01:31 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree with replacing it. They do tend to leak, so a new one would give added piece of mind in addition to improved looks.
Old Mar 17, 2023 | 08:30 PM
grinder11's Avatar
grinder11
IIRC, it is pretty easy. There's a small bolt in the right fender that goes thru to the engine bay to pinch the container tight to the side, and maybe another one, but I can't remember, and several hose clamps. One key is to partially drain the coolant until the reservoir is empty, or near empty. It's really easy to change it out. I guess I should just cough up the $$$ and get a new one. Doesn't make a lot of sense to install all the new hoses I did, then have a 23 year old weak link in the coolant chain! Since it's on my 2000, I'm guessing I have the old style 15lb cap, since it's original, and is black with no markings. So I'll just buy new, and get the 18lb one. Thanks for talking me into spending the $$$ guys!!
Old Mar 17, 2023 | 09:12 PM
vette4fl's Avatar
vette4fl
Tank. GM Genuine Parts 10430189 Radiator Surge Tank https://a.co/d/chqIEeb
18 lb cap. ACDelco GM Original Equipment RC87 18 P.S.I. Radiator Surge Tank Cap https://a.co/d/8rmQBFj
Old Mar 18, 2023 | 09:57 AM
grinder11's Avatar
grinder11
Thank you, vettefl, for the part#s. Thank you again to the others who've posted.
Old Mar 18, 2023 | 10:32 AM
666lisa's Avatar
666lisa
Try this. CLR mix with water and only use enough to dissolve crud. . Cheap, Might work, so if it doesn't ,ur going to buy one anyway.
Old Mar 18, 2023 | 11:21 AM
Smoken1's Avatar
Smoken1
Depending on year that may or may not be the right part number. The older cars had level sensor in them
Old Mar 18, 2023 | 11:33 AM
walleyejack's Avatar
walleyejack
Vinegar for sure, I would try.. even full strength, maybe diluted first time to see how it turns out.
Then crank it up to full strength.. vinegar is used for cleaning everything.
Old Mar 18, 2023 | 11:59 AM
ThomasR's Avatar
ThomasR
Exactly
Old Mar 19, 2023 | 06:04 PM
tabbruzz's Avatar
tabbruzz
They are like 100 bucks...buy one
Old Mar 19, 2023 | 06:33 PM
grinder11's Avatar
grinder11
Please read post 7-
Old Mar 19, 2023 | 08:41 PM
Sound advice here. I would just get a new one (if they are still available) and you know the tank would be good to go for a long time.
Old Mar 19, 2023 | 10:34 PM
redzg's Avatar
redzg
Vinegar is 5 percent acetic acid.
To Ugly stained coolant tanks..
Old Mar 20, 2023 | 03:36 PM
TCFS's Avatar
TCFS
2021 C5 of the Year Finalist - Unmodified
Anyway, you need to unplug the tank to clean it with whatever you want…and rinse it and try again…so better change it.
TCFS
Old Mar 21, 2023 | 01:19 AM
GettnBetter's Avatar
GettnBetter
Cleaning plastics works best using hydrogen peroxide exposed to UV light
Old Mar 21, 2023 | 07:12 AM
Simtech's Avatar
Simtech
I got the Dorman version from Amazon a number of years ago and it is still working great. It was a warehouse deal so I only paid $30 dollars for it. You might check there.
