Trying to see if we can figure out the issue where the DIC shows only odometer info, and pressing the cluster buttons do not change the odometer info. The HUD works fine, the buttons light up properly, although no sound can be heard when depressed. The DIC does display Door Ajar when I open the doors, it also shows tires are low, but then it goes back to odometer info. Basically, the cluster buttons don't respond. Checked fuses 19 and 25, and they are fine. Any recommendations on what else to check, or what the issue may be?
