Hazard Switch Question
Old Apr 17, 2023 | 09:05 AM
LannyL81's Avatar
LannyL81
Default Hazard Switch Question
On my new to me '04 Vert (2 weeks now), found that the hazard switch will not stay in the ON position, have to hold it in to get it to work, turn signals work fine. In searching I see that most have replaced the hazard switch due to the turn signals intermittent operation, did not find any posting where the switch does not latch ON.
Just wondering if there is a non-replacement "fix" for this that I have missed.
Although I have removed the dash pad in my previous '04, not something I am going to do just to replace the hazard switch...will wait until one of the HVAC actuators fails.
Old Apr 17, 2023 | 09:12 AM
yellow2007's Avatar
yellow2007
Sounds like the switch is shot
Old Apr 17, 2023 | 10:10 AM
jdmvette's Avatar
jdmvette
Night Owl for life
You don't need to remove the dash pad but it would certainly help. If you remove all the dash pad bolts you'll be able to lift the pad several inches to give it enough clearance to get to the hazard switch from behind. That's how I did mine the second time when I changed the hazard button from red to shale.
The first time I just jammed it with a socket extension, popped it out the back and reached up from under the knee bolster...broke the old one but didn't want to break the new one
Old Apr 17, 2023 | 10:43 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Sounds like the perfect time to go ahead and do a nice leather dash pad. After all, that should fit into the caveat of “while you are there”.
Old Apr 17, 2023 | 10:44 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Congrats on the new to you "04. Hazard switch issues are common on these cars. However, as you mentioned it is usually an issue with the turn signals that makes people replace it. I'm not sure how you would fix your issue without replacement though. Good luck!
Old Apr 18, 2023 | 10:02 AM
LannyL81's Avatar
LannyL81
From the replies above seems that the hazard switch failing to lock ON is not common, but will require replacement. I like the idea of just lifting the dash pad enough to get my hand in there to get to the switch.
Route99...your suggestion is something I never thought of or have seen. Is a leather dash pad something you have done? If so, pictures and details please.
I assume the GM hazard switch is the one to get?..or are there aftermarket ones that are better?
Thanks for the replies....sure is nice to be have a C5 again!!
Old Apr 18, 2023 | 12:11 PM
jdmvette's Avatar
jdmvette
Night Owl for life
I used this one, clear cap and uses a red led for the light; no issues so far
Amazon Amazon
Old Apr 18, 2023 | 04:46 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
A tad off topic, but I refer to the hazzard button as the ejection seat button for unruly passengers (mostly my wife... )
Old Apr 19, 2023 | 06:43 AM
LannyL81's Avatar
LannyL81
jdmvette: do you remember what brand that switch was you used?
Old Apr 19, 2023 | 10:34 AM
jdmvette's Avatar
jdmvette
Night Owl for life
It's included in the link posted...Dorman
Old Apr 19, 2023 | 02:28 PM
LannyL81's Avatar
LannyL81
Now I see the link....completely missed it the first time.
To Hazard Switch Question
