Corvette C 5
Old May 1, 2023 | 09:38 PM
mrartyp's Avatar
mrartyp
3rd Gear
Default Corvette C 5
How do I get my computer up and running answer a dead battery to pass inspection? Thank you.mrartyp
Old May 1, 2023 | 10:29 PM
killain's Avatar
killain
Oldtimer
What kind of inspection ? If it's state safety inspection I would think putting in a new or charged battery would do it ?
Old May 2, 2023 | 01:56 AM
I think if you are a bit more specific as to what the exact problem is someone here can recommend some fixes to get your car up and running again.
Old May 2, 2023 | 12:40 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Agree with the two gentlemen above.
As Vetteman Jack said, details are very helpful to allow others to help you.
And, as killain suggested a new or fully charged battery will commonly fix this issue. Please understand the C5s are very sensitive to voltage and if the battery is not fully charged your Corvette will not function correctly or perhaps not even function, at all.
I would encourage you to first try a fully charged battery and then if all is not working correctly, please let us know what “symptoms “ your car is presenting and what error codes are showing up on the DIC. Remember, “C” is a current issue and “H” indicates a problem in the past (a History code).
Collectively, I believe we can help you resolve this issue.
Old May 2, 2023 | 01:17 PM
c5arlen's Avatar
c5arlen
Listen Martha... Get some sleep and get centered, reread your question and try again.... Please
To Corvette C 5
