What the heck do I do next
Old May 2, 2023 | 01:45 AM
Riverside California's Avatar
Cruising
Default What the heck do I do next
Is there a tutorial on how to use this forum? I can't seem to find what I'm looking for and the search feature isn't very helpful. I want to see tech posts on the 2001 C5 EBCM and traction control. I fixed the ABS problem by doing the re-soldering on the EBCM circuit board, but the traction control system (TCS) light still pops up and I can't turn it off. When I run the diagnostics its says TCS no com. Need help. Any help on this is much appreciated.
Old May 2, 2023 | 01:51 AM
Try the C5 Tech section and there are forum usage tutorials in the Help Section.
Old May 2, 2023 | 02:03 AM
sayerbloke's Avatar
sayerbloke
Failing that, if you just Google “Corvette forum “ plus the question, Google has the site indexed and can do the search for you.
Old May 2, 2023 | 06:10 AM
Markmbaha1's Avatar
Markmbaha1
I like your answer lol. I look at this foum on my phone and search was about useless (unlike the forum). Then I found advanced, and it onky improved my search results minimally. As the other member said if you simply search your topic on the internet, the results come back very specifically to topics/posts/threads in this forum.
Old May 2, 2023 | 10:51 AM
indebt's Avatar
indebt
Veteran: Marine Corps
2023 C5 of the Year Finalist - Modified
Like mentioned, I always use Google....add C5 corvette forum at the end and boom!! The search feature here, go to Advanced like you said, and than there's a spot to search a specific or multiple forums. You would want to search in C5 Tech and C5 General. It is easier just to use Google though.
Old May 4, 2023 | 04:00 PM
DDaaryl's Avatar
DDaaryl
Google is the answer as stated above. The search feature on this site has never helped me.
Old May 4, 2023 | 07:54 PM
v8srfun's Avatar
v8srfun
Searching Google may help but I would definitely invest in an oem service manual and run through the diag process for the code you are getting. Then when you know what the problem is you come back and see if the internet has a fix.
To What the heck do I do next
