Surprise!!!
Old May 6, 2023 | 07:31 PM
MSOH's Avatar
MSOH
Veteran: National Guard
Default Surprise!!!
So, I took off my intake manifold last night to do a preemptive oil pressure sender replacement and relocation. When I got the manifold off, this is what was waiting for me underneath....YUCK!! I got this car in December, had been in Texas most of its previous life. I think the PO was off-roading it! It's now getting all new top end gaskets!
Old May 6, 2023 | 08:40 PM
killain's Avatar
killain
Oldtimer
Good time to get the vacuum out, but it looks like you doing a good job, Id there is anything else you have in mind on the top of the engine, now's the time !
Old May 6, 2023 | 09:26 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
How many miles on the car? If the car has 20k, I'd say your right about being taken off road.. However, if the car has 120k it looks a little normal. Also, where did you buy the car in Texas? If you bought the car in West Texas, you can expect a thin layer of dirt on just about everything.
But, as Riggins says "Texas Forever."
Old May 6, 2023 | 10:36 PM
v8srfun's Avatar
v8srfun
That looks normal for a car with some mileage on it but yes while you are there the gaskets are cheap.
Old May 7, 2023 | 12:40 AM
MSOH's Avatar
MSOH
I bought the car here in Ohio, but the Carfax indicated it was bought in Uvalde TX, and lived there for over 15 years. It only has 66K on it. I thought about changing the intake manifold, but some other expenses got in the way. Oh well, that will give me something to do later.
Old May 7, 2023 | 07:46 AM
ThomasR's Avatar
ThomasR
Looks normal. It's amazing how much dirt can get trapped there.
Old May 9, 2023 | 11:57 AM
MSOH's Avatar
MSOH
It really is amazing! Got it all back together and started it this morning, purrs like a kitten! Success!!!All the gaskets and injector O rings were original, Yikes!
Old May 10, 2023 | 12:39 PM
c5arlen's Avatar
c5arlen
Miles?
Old May 10, 2023 | 01:05 PM
nolimits1320's Avatar
nolimits1320
2nd Gear
That's pretty typical. Your knock sensors look cleaner than typical. Usually the rear one gets enough moisture to get significant corrosion.
Old May 10, 2023 | 06:43 PM
MSOH's Avatar
MSOH
That’s probably from spending 15 years in Texas. To answer the other question, it has just over 66,000 miles on it. It was one of those projects that kept on needing more! When I got the coil packs off the valve cover, the covers were an oily mess so there went the valve cover gaskets, and of course the intake and throttle body gaskets went with that. Then, the base of the injectors on the manifold had dried fuel residue, so of course the injector o rings had to go, they were hard little rubber donuts! But all is done.
Old May 11, 2023 | 02:14 AM
Good move to replace those gaskets.
Old May 11, 2023 | 09:31 AM
MSOH's Avatar
MSOH
Thanks! They were definitely original!
Old May 12, 2023 | 04:18 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
That's what my 113,000 engine looked like when I pulled my manifold. I got a knock sensor CEL, the front one was submerged in water. A good vacuuming and all is well now. To get the crevices I used a trans fluid funnel stuck to the end of my shop vac, the little end really gets into the head bolt
cavities well.
Old May 12, 2023 | 05:25 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
it does not need to go off road, the fan setup on the C5 sucks all the dirt it can find and blows it all over the engine
Old May 12, 2023 | 05:38 PM
MSOH's Avatar
MSOH
Those small gaps down to the head bolts are grime magnets!! cdee, your definitely looks worse than mine, although mine only has 67K on it! You went one step farther than I did, I didn't take off the valley pan.
Old May 12, 2023 | 07:47 PM
vette4fl's Avatar
vette4fl
Nice cleaning job!
To Surprise!!!
