Can’t find replacement tires
Old May 12, 2023 | 11:04 AM
Thrill2Drive's Avatar
Thrill2Drive
2nd Gear
Default Can’t find replacement tires
Looking for new tires for ‘01 ZO6 with staggered sizes: 265 40 ZR17 in front and 295 35 ZR18 in rear. Goodyear Eagle F1’s not available nor much else other than Continental ExtremeContact using 255 45 ZR17 instead for front.
Any suggestions?
Old May 12, 2023 | 12:06 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
You actually answered your own question with the continentals. Stock tire size for the Z06 is pretty much impossible to find. However, it is okay to go up or down a size. The other option would be to buy bigger rims so you can then buy tires to fit. Good luck!
Old May 12, 2023 | 12:17 PM
ssmuff's Avatar
ssmuff
2021 C5 of the Year Finalist - Unmodified
I just recently purchased 275/40r17 Nitto G2 for the fronts and 305/35r18 Nitto 555R2's for the rear.
Old May 12, 2023 | 12:32 PM
c5arlen's Avatar
c5arlen
OK.. Here's what you do.. Go to Americas Tire / Discount Tire... Trust them, they know what they are doing better than you and get the Michelin tire that's designed for the C5. No brainer
Old May 12, 2023 | 03:13 PM
MetalMan2's Avatar
MetalMan2
What sizes, though? They can't make unavailable tires magically appear. We can go to their website(s) and peruse the entire collection of what they have available (or not available, for that matter).
Previously I ran 255/40/17 & 285/35/18. They worked okay, but I ended up deciding I wanted a bigger tire and went 18/19 C6 base wheels with 255/40/18 $ 285/35/19. Added 1/2" more ground clearance...
Old May 12, 2023 | 04:25 PM
Beast's Avatar
Beast
2 years ago, maybe 3, I went with wheels and tires from tire rack
front 18x9.5 with 275 35 tire
rear 19x10.5 with 305 30 tire
lots more tire options with these rims.
If you want to keep your rims, a 275 40 17 should fit in the front, and a 285, 295, or 305 should fit in the rear
To Can’t find replacement tires
