C5 Jack?
Old May 22, 2023 | 08:59 AM
Markolc1981's Avatar
Markolc1981
Originally Posted by Robert Barcus
I just got a deal on a 7,000 quikjack. Do i need pucks to use it?
Yeah. My buddy has the 5000 and uses the pucks and these rubber things that come with the quickjack. It will make sense when you don't the first time.
In other news, I found a set of 4 rubber jacking pucks on Amazon for $14. I bought as a backup set, but they're such good quality, I use them all the time now.
Old May 22, 2023 | 10:58 AM
mfi2000's Avatar
mfi2000
One thing about the quick jack..with enough force you can knock the car off it...
while replacing the sway bar end links I used a bit too much force on the front and the car slid off the jack on the front corner...didn't hit the floor though..got lucky. I was able to lower it and reset it..scary...
I would put jack stand under it now if your going to be hard wrenching it under there.
Old May 22, 2023 | 11:52 AM
Alley Oop's Avatar
Alley Oop
You need pucks between the jack and the Vette's frame.
Old May 23, 2023 | 02:26 AM
Originally Posted by SkH
So basically a good low profile jack with the pucks and 4 decent jack stands will be fine without needing a long reach jack is what I'm hearing. Correct?
You are hearing correcctly.
Old May 23, 2023 | 04:38 PM
c5arlen's Avatar
c5arlen
My Corvette C5 is perfect and dose not need to be jacked up... Tires are always new... I don't have flats!
Old May 24, 2023 | 05:13 PM
indebt's Avatar
indebt
Veteran: Marine Corps
2023 C5 of the Year Finalist - Modified
No pucks needed. The rubber blocks fit nicely in the openings where the pucks go. Thats how I lift mine, multiple times. So, whatever you want to use is fine.
