Swaybar Bushing bracket hole cross threaded - thoughts?
Old May 17, 2023 | 01:31 PM
SBDCWI's Avatar
SBDCWI
Default Swaybar Bushing bracket hole cross threaded - thoughts?
Hi All,
I found a bit of information with regard to the drivers side (front) say bar bushing bracket holes. Mine are cross thread and the bolts will not seat all the way home. I have the bolts in about 3/4 of the way in, but don't want to tighten further in fear of snapping the bolts themselves. The bushing itself is not moving, however curious if anyone has feedback on driving the car with the bolts tight, but no seated to the frame?
No doubt, likely best bet is to drill and re-tap, and insert a helicoil. Has anyone have experience in doing so, without using a drill-press I am concerned about getting the hole straight.
Greatly appreciate any feedback, thank you!
Old May 17, 2023 | 03:29 PM
BmoreRnsDeep's Avatar
BmoreRnsDeep
I striped one of the bolt holes on the rear swaybar bracket. I drilled it out and used a heli coil in it with red thread lock. It tightened up great after that.
Old May 17, 2023 | 03:38 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I'd take the bolt out and cut it down. If there are enough threads, the bolt will hold. It is important that your bracket has presure against it.
Or.... redo the threads. That is what I would do.
Old May 17, 2023 | 09:54 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Helicoil without a doubt. Fix it right.
There are a lot of people that think helicoils are a band aid but the reality is a properly done helicoil is worlds better than straight aluminum threads.
Old May 18, 2023 | 10:41 AM
LWSZ06's Avatar
LWSZ06
I would remove the bolts and chase the threads in the mount with a tap. Inspect the threads, and if good, thread in a new bolt to torque specs.
If that does not fix the problem, then use a helicoil to repair.
Larry
Old May 18, 2023 | 10:44 AM
Mr. Black's Avatar
Mr. Black
Larry
I would normally agree with you but when OP said the bolts are as much as 3/4s the way in I would not have high hopes in the chasing department. It would be one thing if just the first couple of threads were dicked up.
Old May 21, 2023 | 02:53 PM
SBDCWI's Avatar
SBDCWI
Just an update for any folks who run into a similar issue with the tapped threads in the frame. I greatly appreciate everyone's suggestions and help! I will still install Helicoil's in the future, but for the time being as able to chase the thread very easily, all went back together great. Only second step was having to remove the nut on the endlink so that bar could move a little bit to help things align correctly. Easy enough and fixed!
Cheers!
To Swaybar Bushing bracket hole cross threaded - thoughts?
