1999 c5 defroster question
Old May 17, 2023 | 05:27 PM
Rocketship91's Avatar
Rocketship91
Default 1999 c5 defroster question
When I hit the front defrost button, should the AC button light up and turn on? I'm thinking not but is there something to look at to get it to operate correctly? Thanks!
Old May 17, 2023 | 05:42 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Mine does as long as the temp is above about 40 degrees. Does your ac work?
Old May 18, 2023 | 06:32 AM
Rocketship91
Ac does work nice and cold!
Old May 18, 2023 | 01:30 PM
c5arlen's Avatar
c5arlen
First things first... You'll be better off if you press the button gently, don't "hit it". 🤨
Old May 18, 2023 | 02:03 PM
bookyoh's Avatar
bookyoh
The compressor should come on with defrost. It is for defogging.
Old May 18, 2023 | 03:02 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Yes, the AC light should turn on with the defrost button. The AC compressor removes moisture from the air. Since condensation is excess moisture, having the AC on helps. Even when it is cold, the compressor still helps remove moisture even though the air is blowing warm.
To 1999 c5 defroster question
