rear caster
Old May 29, 2023 | 07:43 PM
ball-z's Avatar
ball-z
Default rear caster
question for alignment techs, 1999 c5 i had a 4 wheel align done and the tech moved 1 lower control arm adjuster to bring in camber and reset the toe. I know rear caster is not measured but it is adjustable, by him moving 1 adjuster did he move the caster? Also he did not remove the pins on the machine plates . It was done at a tire dealer.
