C5 Fuel pump
Old Jun 19, 2023 | 09:04 PM
hpdracing's Avatar
hpdracing
5th Gear
Default C5 Fuel pump
My 2001 fuel pump has died . What are some good replacement options that are drop in and not universal that requires a lot of work? Looking for upgrade as I have about 600 hp
Old Jun 21, 2023 | 06:14 PM
grinder11's Avatar
grinder11
AFAIK, I have an OEM fuel pump and its good enough for a 427 making 617hp@crank. I know I have never replaced it......
Old Jun 23, 2023 | 09:17 AM
HardcoreABN's Avatar
HardcoreABN
600 crank and 600 wheel are very different things....
and the factory fuel pump is not supporting either on its own. You may think you have the factory fuel pump....
Old Jun 23, 2023 | 09:30 AM
smitty2919's Avatar
smitty2919
Racetronix has a kit. Need an upgraded wiring harness as well though.
Old Jun 23, 2023 | 09:31 AM
smitty2919's Avatar
smitty2919
What is your injector duty cycle?
With my cam only C5Z I'm getting to the limit on stock injectors. With heads/E85 planned this winter, new injectors and 340 pump are going in (ignore the E85 portion requiring a bigger pump). Curious how you are making that much HP and still on stock injectors/pump.
To C5 Fuel pump
