High Output Alternator
Old Jul 7, 2023 | 02:37 PM
FreedomFighter's Avatar
FreedomFighter
Default High Output Alternator
Hi Guys, I have been reading many different threads and was looking for a little advice. I have added after market lights from Sharp Lighting Innovations, JVC touchscreen stereo, and a Skar 800 amp and 12 inch subwoofer and I killed one battery, probably because I didn't remove the negative once while doing installation, and it seems like when the car goes to idle the charge drops to the 12's and 13's at times.
So I am going with a high output alternator and was wondering if any one had any advice on Amps or Manufacturers. Also I was looking at the 220amp from Powermaster at Summit Racing.
https://www.summitracing.com/parts/pwm-48969
Any thoughts would be appreciated.
Old Jul 7, 2023 | 02:45 PM
ncali's Avatar
ncali
before you go changing alternators , read the sticky threads in the tech section on the c5 alternators
Old Jul 7, 2023 | 02:49 PM
snaitaz@aol.com's Avatar
snaitaz@aol.com
what he said. Also, I have tried using Power Master and it still couldn't keep battery charged. So I kept the OEM and had it rewound to have greater output. No problems since. Cheers!!!
Old Jul 7, 2023 | 07:49 PM
redzg's Avatar
redzg
Ah! But when, by who, and where? I ask when because so many shops have gone under in the last few years. Do they have a website, and maybe work with mail order upgrades?
Old Jul 7, 2023 | 08:05 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I have an AutoTech Engineering 320 amp unit. No charge fault light. No issues. Works just fine. Been in my car for over a year with 3800w of stereo.
Old Jul 7, 2023 | 08:40 PM
snaitaz@aol.com
A year ago, local electrical engine repair shop Bakersfield. Mostly does many of the oil rigs motors but he does it all. Cheers!!!
Old Jul 8, 2023 | 12:37 PM
Prop Joe's Avatar
Prop Joe
You can call these guys and they can tell you if they can boost the output of your existing C5 Alternator. This place has been in business since 1954. They may be able to build you one and ship it for an outright sale? If nothing else can steer you towards a solution. Give Larry a call.
https://www.mgautoelectric.com/auto-...c-part-service
Old Jul 8, 2023 | 07:51 PM
vette4fl's Avatar
vette4fl
Looks like a good source. Added to my catalog. 👍
To High Output Alternator
