2003 Maintenance
Old Jul 10, 2023 | 04:51 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default 2003 Maintenance
As some of you know, i have a new to me 2003 Vette with 32k miles and looking to do some maintenance/upkeep. Please let me know if I am missing anything from my list!
  1. Fluids
    1. Transmission Fluid
    2. Differential Fluid
    3. Power Steering Fluid
    4. Coolant
      1. Fluid
      2. Expansion Tank
      3. Hoses
    5. Clutch Fluid
  2. Suspension
    1. C5 Z51 Sway Bar and Bushings
    2. Sway Bar End Links
    3. Outer Tie Rod Ends
  3. Belt Drive
    1. Drive belt and tensioner
    2. AC belt and tensioner
    3. Idler pulley
Old Jul 10, 2023 | 05:08 PM
Fcar 98's Avatar
Fcar 98
20 years old. Plugs and wires. Probably still good but if you plan on keeping the car change because of age. The older that car gets the harder they will be to remove
Old Jul 10, 2023 | 06:24 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Have you installed a LCM5 yet?
Old Jul 10, 2023 | 06:34 PM
Dirty Dog's Avatar
Dirty Dog
LCM5. Skip shift eliminator. Brake fluid. Brake pads & rotors. Blower.
Old Jul 10, 2023 | 11:50 PM
xcarter's Avatar
xcarter
Check the parking brake. Mine was 0% functional, needed new shoes.
If you're doing the front-engine parts, peak at the Harmonic Balancer, might be due, might not.
Old Jul 10, 2023 | 11:51 PM
xcarter's Avatar
xcarter
Check the tire age...
Old Jul 10, 2023 | 11:53 PM
xcarter's Avatar
xcarter
Ok last one,
Check and clean the udder drains.
Old Jul 11, 2023 | 07:58 AM
wydopnthrtl's Avatar
wydopnthrtl
Some drivers seats have a fore/aft clunk as there are some small plastic bushings that have excessive play.
Clean the door and hatch seals and coat w/dielectric grease.
Install jacking pucks
The headlight motors have a weak gear. Have yours been upgraded?
I added a battery charging wire and have it routed to the fender vent. When parked longer than a week I plug it in.
You didn't mention brake fluid... I flush mine every two yrs.
Old Jul 11, 2023 | 08:17 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Why dielectric for those? I think silicone grease is a better option for those rubber parts.
Old Jul 11, 2023 | 08:31 AM
Missileboy's Avatar
Missileboy
Do a complete brake system bleed and flush. Change out the fuel filter/regulator-didn't see those on your list!
Old Jul 11, 2023 | 10:42 AM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Thanks all for your comments, I am going to do the brake fluid with new C6 Z51 Calipers & Pads/Rotors later this year. Appreciate the insight!
Old Jul 11, 2023 | 11:15 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
The owner's manual calls for dielectric grease. I have found that it works great.
Old Jul 11, 2023 | 11:19 AM
Missileboy's Avatar
Missileboy
Good deal, replace the 4 soft lines with steel braided ones while you are in there (if you weren't already). My stock rubber hoses actually looked okay and were still pliable but it is much better hitting the peddle and feeling that nice solid braking feel with the new lines and fluid!
To 2003 Maintenance
