C5 diff, exhaust or cam first?
Old Jul 15, 2023 | 11:00 PM
walleyejack's Avatar
walleyejack
Originally Posted by Vader_C5
Priority #1, get the balancer replaced, especially if there is wobble. After that, start with exhaust and go from there.
If doing the balancer, you are more than halfway there doing the cam, may as well do it once and be done
Old Jul 16, 2023 | 01:46 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Balancer then gears.
Old Jul 16, 2023 | 02:51 PM
1998LS1's Avatar
1998LS1
Originally Posted by vette4fl
Both points above are good advice.
If you do the balancer I would also blow out the radiator and condenser fins, and check the age of the coolant hoses. Mine had a 2004 date stamp when I bought it in 2021!
This is also great advice on an aging car. I replaced the radiator, ac condenser, water pump, t-stat, and hoses in addition to belts/pulleys/tensioners when I did the harmonic balancer on mine.
Old Jul 17, 2023 | 10:57 AM
If the balancer is wobbling, definitely get that fixed as soon as possible. Next I would do the differential upgrade - it will be a major improvement over the 2.73 gears in there now. A good catback exhaust will give you a better sound from the car. If you want to go further, then consider the other options like cam, headers, etc.
Old Jul 17, 2023 | 11:41 AM
vette4fl's Avatar
vette4fl
Looks like benji done bailed…
