Air dam problem
Old Jul 21, 2023 | 11:21 AM
Longhorn49's Avatar
Longhorn49
1st Gear
Default Air dam problem
Hi,
I have 222000 miles on my C5,2000 Vette
why is my air dam coming off? Replaced 3 times this year!!
no objects hit!,
Old Jul 21, 2023 | 11:36 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum! I think pictures would be very helpful here. It is VERY common for the air dam to scrape on things. It is actually designed to be able to do so. It can naturally wear away over time. However, it certainly shouldn't need to be replaced 3 times in a year. I suspect you have an issue with how it is installed. As I said, several detailed photos of your issue should help us to better diagnose the root of your problem.
Old Jul 21, 2023 | 12:17 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Bingo
Old Jul 21, 2023 | 12:36 PM
rw03vette's Avatar
rw03vette
Try the re-inforcement plates like these from Zip:
https://www.zip-corvette.com/97-04-f...orcements.html
Old Jul 21, 2023 | 06:24 PM
grinder11's Avatar
grinder11
Reinforcement plates are helpful. I put some on a couple years back. But I've never had any issues like the OP! I suspect Warlord nailed it, and if billschroeder5842 seconded it, I'll third it, if that's even a thing......
Old Jul 21, 2023 | 07:44 PM
killain's Avatar
killain
Oldtimer
I made my own out of 1/8 sheet aluminum. The plastic things break in a few months.
Old Jul 22, 2023 | 01:27 AM
I agree - those plates really help keep the air dams in place.
Old Jul 22, 2023 | 09:56 AM
grinder11's Avatar
grinder11
I agree auminum would be stronger. But my plastic ones have been on for years, and have never cracked or broken. I've also hit a few speedbumps that were a bit too high, in my opinion. What are you running over????
To Air dam problem
