Hood light
Old Aug 12, 2023 | 11:43 AM
kwiki's Avatar
kwiki
4th Gear
Default Hood light
Is there a way to disable the hood light? I like to leave the hood open at shows and etc. A switch would be nice.
Old Aug 12, 2023 | 12:15 PM
yellow2007's Avatar
yellow2007
Unplug the connector behind the radiator. Open hood and look down to the right of the eadlight
Old Aug 12, 2023 | 01:01 PM
jcgunn's Avatar
jcgunn
If your light is OEM, it has a mercury switch to turn on and a timer on the circuit. Should go out on it's own after 15 minutes. Give it a try.
Old Aug 12, 2023 | 01:57 PM
rrwirsi's Avatar
rrwirsi
with unplugging the connection although make sure you water proof tape off ends.. Or, just remove the bulb from its connection and leave the bulb in light housing. I do not trust anything electric in the C5 going out by itself.
Old Aug 12, 2023 | 03:12 PM
Mikado463's Avatar
Mikado463
On my '02 ZO6 it goes out on its own without a hitch. I haven't timed it but I'm guessing it's 10 minutes or less
Old Aug 13, 2023 | 04:39 AM
It will time out as others have mentioned, but unplugging it like yellow2007 stated will also work.
Old Aug 13, 2023 | 05:08 AM
alssiri's Avatar
alssiri
You can add a switch to turn it on/off when ever you want.
Ahmad
Old Aug 13, 2023 | 03:47 PM
Thrash's Avatar
Thrash
I tapped into the cable & put in a box-style rocker switch that flush mounted to the liner (put a bit of hot glue around it on the underside to keep it in place). I did this 15 years ago, so not sure what switch it was but it was from RadioShack, RIP.
Old Aug 14, 2023 | 06:39 AM
rwlc5's Avatar
rwlc5
Replace the bulb with an LED. It has less of a draw. Before you remove the old bulb unplug the light and let it cool off completely. It will burn your fingers. And as someone said after 15 minutes the light shuts off
Old Aug 14, 2023 | 07:55 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I removed the bulb from mine....
Old Aug 14, 2023 | 10:15 AM
jjc508520's Avatar
jjc508520
My light was out and it was the pigtail up front that had been disconnected - I think by whoever I took it to last for service - thanks for the reminder!
Old Aug 14, 2023 | 01:28 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
I bought 2002 new and the hood light unplugged is probably my first and only mod. Bone stock, 16,xxx miles.
Old Aug 14, 2023 | 04:41 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I installed this on mine. Pretty easy and works well. A much better solution than leaving things un plugged and dangling.
https://www.corvettecentral.com/4650...oaAuC4EALw_wcB
Old Aug 14, 2023 | 09:18 PM
xcarter's Avatar
xcarter
They do (should) shut off on their own. Mine was actually disconnected when I got my car and I didn't realize it for a couple of weeks. Even if it stays on things like the hood light and parking lights (if you want to leave your headlights up) shouldn't drain your battery that fast to worry about. Bonus, at shows there's always someone around to give you a jump
Old Aug 17, 2023 | 05:19 PM
RWD-FAN's Avatar
RWD-FAN
I can confirm it goes off after not too long. I met up with a few people for a drive last weekend and someone pointed out the hood light was on. By the time I took this pic a few minutes later, it was off.
And YES the dealer's name has been removed- that was my very first mod (just bought it saturday)
To Hood light
