Quickjack setup. Down button is not working
Old Aug 19, 2023 | 02:39 PM
bac00's Avatar
bac00
6th Gear
Default Quickjack setup. Down button is not working
I'm at the point in setup where you bleed the system. Up to now, I believe I've done everything as directed. Each Quickjack is up on the rubber blocks and the "Up" button worked as expected. But the "Down" button makes a single, low-level tick sound when I press it and nothing else. Support is not available from them on the weekend, though I did submit a support ticket. Any help appreciated!
- Bob
Old Aug 19, 2023 | 02:55 PM
grinder11's Avatar
grinder11
I don't have a QJ, but I do have a 2 post lift. On my lift, the lift is lowered with a lever that bleeds off hydraulic fluid. If you QJ does the same thing, it may take some time before it lowers with no weight on it. With no weight on mine, it takes awhile to lower. I don't know much about the QJ. Wish I could help more...
Old Aug 19, 2023 | 04:24 PM
Davcruz's Avatar
Davcruz
If you have not already, try putting some significant weight on them. I had mine side by side and then stood with 1 foot on each.
Old Aug 19, 2023 | 05:01 PM
bac00's Avatar
bac00
6th Gear
That did the trick. Thank you.
For anyone who may run across this post in the future, I'm only about 150 lbs. I stood on the lower end of each one (the other ends are up on those blocks). They go down slowly and a little jerky at first, but it works
Now to finish setup!
Old Aug 22, 2023 | 12:54 AM
AntonioZ06's Avatar
AntonioZ06
stand on the quick lift and raise/lower it several times. Takes a few cycles to bleed the air out and clear up the jerky motion
Old Aug 22, 2023 | 10:23 AM
Davcruz's Avatar
Davcruz
Good deal, the QJs are not hydraulic down, just gravity, so sometimes they will stick a little, usually for me it is at the very bottom of the drop. I think bleeding the air out using the schrader valves helps some too, and I check them periodically and still get air out, even after using them many times now.
Old Dec 27, 2023 | 08:30 PM
ChrisGro16's Avatar
ChrisGro16
3rd Gear
hey Bob,
I'm doing my initial set up now. I've bled out the air and seem to have a similar issue. I can go up fine and back down fine if I raise it roughly quarter to the first lock out point, but the right side lags. If I go higher than half to lock out I can't get it to go back down. I'm just worried about it not going up and down evenly when I jack up my car. Any suggestions
Old Dec 27, 2023 | 10:25 PM
MetalMan2's Avatar
MetalMan2
Are you guys filling the air cylinders with air? They are supposed to be 40-50psi according to the manual. These air cylinders help "push" the Quickjacks to the flat position, you shouldn't need weight (i.e. standing on them) when the air cylinder is adequately filled.
https://www.quickjack.com/quick-tips...ng%20correctly.
Old Dec 29, 2023 | 08:48 AM
bac00's Avatar
bac00
6th Gear
Originally Posted by ChrisGro16
hey Bob,
Once I successfully made it through the bleeding process, they worked under the car exactly as expected.
Old Dec 29, 2023 | 09:26 AM
bac00's Avatar
bac00
6th Gear
This was my understanding, too. Air cylinders were correctly inflated, but, during the bleeding process, the jacks simply would not go down under their own weight. I have since learned that many others had the same issue.
Old Dec 29, 2023 | 10:48 AM
jcj63's Avatar
jcj63
According to my QuickJack manual this is a normal condition when no load is on the jack. It even says to step on it to get it down.
Old Dec 29, 2023 | 12:03 PM
Fast one's Avatar
Fast one
I haven't put air in the cylinders for at least three years, the jacks lower all the way to the floor on their own with no air pressure.
Old Dec 29, 2023 | 02:00 PM
roegs's Avatar
roegs
Mine used to go all the way down by themselves until this past summer. We had a heavy rain and water blew into the garage and the rear pivot point of one of the jacks had water around it for a few days. Even though I had kept that kept all the quickjack lube points well oiled, that pivot point rusted and it no longer allows the jack to lower completely under its own weight.
Old Dec 31, 2023 | 10:36 AM
ChrisGro16's Avatar
ChrisGro16
3rd Gear
This is where I'm at. Cylinders inflated correctly, absolutely no air in the lines. Still won't go down and I don't get it. I didn't want to proceed with jacking up the car at this point but i dont know what else can be done. Quickjack sent me their "updated" bleeding procedure when i spoke to them last but did nothing.
Old Dec 31, 2023 | 10:47 AM
ChrisGro16's Avatar
ChrisGro16
3rd Gear
Interesting I'll read over to check
Old Dec 31, 2023 | 12:27 PM
Missileboy's Avatar
Missileboy
It's normal. Once bled, you stand on them to make them come down if not under a load. Mine is the same way, but once the car is on them, when I lower it, they go all the way down.
To Quickjack setup. Down button is not working
