Cat Question
Old Aug 19, 2023 | 03:17 PM
jost6453's Avatar
jost6453
Default Cat Question
‘04 Coupe. I had a cat come apart inside. If rattled like crazy so I cut a small hole in the bottom of each one and gutted them as a ‘temp’ fix. I’d like to put some high-flow cats back on but the inlet/outlet offset makes a bolt of option difficult. Does anyone make an adapter that would line up the inlet & outlet pipes? Or can you buy cats that have the offset built in? I’m trying to avoid dropping the exhaust if possible. TIA.
