C5 Oil Dipstick
Old Aug 19, 2023 | 06:00 PM
busta808's Avatar
busta808
Default C5 Oil Dipstick
Aloha!
I have an ‘82 Vette that just received an Ls1 from an ‘01 Z28. I’m using a batwing oil pan from a ‘99 Vette. Does anyone know if the dipstick from my Z28 LS1 is reading accurately considering I swapped to the batwing?
Does anyone know if both engines use the same location for the dipstick to enter the block?
does anyone have the dipstick from an early year C5 available to measure how much the dipstick sticks out of the tube on the bottom?
Any help is appreciated.
Mahalo!
Old Aug 20, 2023 | 04:54 PM
grinder11's Avatar
grinder11
Originally Posted by busta808
Aloha!
Mahalo!
The only way you'll know for sure is to change the oil. The LS1 with C5 batwing pan holds 6.5qts of oil with oil and filter changes. Most guys run 6.5-7qts. Do the change, insert dipstick, and check where the level is. The '97-'00 C5 LS1s used a different dipstick than the '01-'04 C5 LS1s. BOTH have been long discontinued.......
Old Aug 20, 2023 | 05:33 PM
busta808's Avatar
busta808
Thanks for the response. That’s just what I’ll do.
To C5 Oil Dipstick
