Exhausting gasket search
Old Sep 1, 2023 | 03:34 PM
zofoman's Avatar
zofoman
Default Exhausting gasket search
What gaskets do you guys use/recommend when installing an over the axle exhaust? I'm talking about the two bolt-hole muffler/flange to pipe connection. Parts houses are pushing the WLK-31537 (Walker) and is supposed to fit, but its a smaller inside diameter than the actual pipe size...I want no restriction. Genuine GM gaskets are $30+ something...aftermarket "Corvette suppliers" are in the $25 +/- range and Amazon/Ebay are priced from little to nothing to what's in your wallet? As a matter of principle I refuse to pay high dollar for these two simple exhaust gaskets...on the other hand I want them to not leak for a few thousand miles.
Old Sep 1, 2023 | 03:38 PM
Smoken1's Avatar
Smoken1
I used GM, IIRC
Old Sep 2, 2023 | 08:49 AM
LWSZ06's Avatar
LWSZ06
Amazon Amazon
Old Sep 2, 2023 | 09:05 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, as LWSZ06 provided the link. Use those.
I put those exact gaskets on my Z06 after I did a "X" pipe addition. No worries and no leaks. Remember to torque them evenly (I seem to remember 30lbs ??) so as to not get leaks. Also use a floor jack, a board and a level to get your tips straight or (if you are like me) you will loose your mind seeing alignment problems.
Old Sep 2, 2023 | 09:39 AM
zofoman's Avatar
zofoman
Ok, thanks to you both for the info...much appreciated. There was a time you could get simple parts that actually fit...now one seems to have to roll the dice & pray.
Yes, I agree on the alignment...more than once, in the past, on other vehicles, I've had to straighten things by force to get the right "look".
Old Sep 5, 2023 | 04:22 PM
smitty2919's Avatar
smitty2919
Red high temp RTV....
To Exhausting gasket search
