Anyone install this battery cuttoff switch?
Old Sep 6, 2023 | 10:09 AM
Six7390gt's Avatar
Six7390gt
2021 C5 of the Year Finalist - Unmodified
St. Jude Donor '25
Default Anyone install this battery cuttoff switch?
Our C5 doesn't get driven in the winter much, and it will sometimes get shuffled out of the garage and into our 3 enclosed sided carport with a cover on it, and there is no easy power for a battery tender. I run the top post version of this on our 60's cars and have had no problems with them. Is there room for this battery disconnect switch in a stock C5?
https://www.amazon.com/gp/product/B09MRHKLGH/ref=ox_sc_act_title_1?smid=AONZIIRJ6WPT6&th=1 https://www.amazon.com/gp/product/B09MRHKLGH/ref=ox_sc_act_title_1?smid=AONZIIRJ6WPT6&th=1
Old Sep 6, 2023 | 04:12 PM
yellow2007's Avatar
yellow2007
Others will chime in but I would imagine killing battery power to the cars systems for any length of time can't be good.
Old Sep 6, 2023 | 04:27 PM
schmuckingham's Avatar
schmuckingham
I only use this style on street cars.
https://ceautoelectricsupply.com/pro...cuit-breakers/
Old Sep 6, 2023 | 04:33 PM
JMG2's Avatar
JMG2
Moderator
I would say better to connect a trickle charger than disconnect the battery --the computer will have to relearn when restarted
Old Sep 6, 2023 | 05:23 PM
grinder11's Avatar
grinder11
^^^^^^^^^^This 100%^^^^^^^
I have a Battery Tender Jr. Love it. They're only $30, give or take a few $. OP-Disconnecting the battery long term probably does no damage, but as JMG2 said, the computer has to relearn some things again. Not like its not going to run. But it won't run quite as well as it did until it relearns some things. Another issue is your memory settings will be gone. Some guys store a lot of radio stations, up to 36, iirc. Better to leave the battery connected. Also, while the kind of disconnect you're showing isn't a problem, some of them with a green **** you twist to connect/disconnect can be problematic. In one case the threads bottomed out due to female threads not being tapped deep enough. It took 2 shops that couldn't figure it out until C&S Corvettes did........
Old Sep 6, 2023 | 05:40 PM
Six7390gt's Avatar
Six7390gt
St. Jude Donor '25
Thanks for chiming in everyone. As always, some good help in the C5 forum. I won't install the battery cutoff switch, I'll just try to get it out in good weather and run a trickle charger more often.
Old Sep 6, 2023 | 06:33 PM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
I attached my car to an external solar panel to tickle charge my battery via a quick release connector. I didn’t want to run an extension cord across my front doorway to my car.
Old Sep 6, 2023 | 06:37 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Clean C5! I use the CTEK tender and connected their quick release to the battery terminals. Works great for quick connect/disconnect.
Old Sep 7, 2023 | 05:43 AM
When I bought my 2003 C5, it had one of those battery disconnect switches installed by the previous owner. I guess it worked well for him, but I took it off not long after the purchase. I always kept a Battery Tender Plus connected to the car so the battery was always fully charged.
If you can, find a way to either install an electrical outlet in the carport or run a heavy duty extension cord out to the car.
Old Sep 7, 2023 | 09:19 AM
hyperv6's Avatar
hyperv6
Simple battery tender is the way to go. In the winter time my garage looks like I have three electric cars plugged in.
Too often the disconnects are cover an electrical issue someone can't or won't fix.
Old Sep 7, 2023 | 11:46 AM
redzg's Avatar
redzg
If a Frankenstein blade switch is used, isn’t a statement such as “It Is Alive!” required with every spark on contact?
Old Sep 7, 2023 | 12:51 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I do the C-Tek thing as well, through my cigarette lighter, works like a champ!
To Anyone install this battery cuttoff switch?
