Noob C5 Owner Questions
What interior and exterior LED lighting brands have folks had luck with?
For LED lights check out VetteLights, thats were I got all mine from
From page 6-3 of my 1999 owners manual:
Fuel
Use premium unleaded gasoline rated at 91 octane or
higher for best performance. You may use middle grade
or regular unleaded gasolines, but your vehicle may not
accelerate as well.
It is recommended that the gasoline meet specifications
which have been developed by the American
Automobile Manufacturers Association (AAMA) and
endorsed by the Canadian Motor Vehicle Manufacturers
Association for better vehicle performance and engine
protection. Gasolines meeting the AAMA specification
could provide improved driveability and emission
control system performance compared to other
gasolines. For more information, write to: American
Automobile Manufacturer’s Association, 7430 Second
Ave, Suite 300, Detroit MI 48202.
Be sure the posted octane for premium is at least 91
(at least 89 for middle grade and 87 for regular). If the
octane is less than 87, you may get a heavy knocking
noise when you drive. If it’s bad enough, it can damage
your engine.
The Corvette is a premium car. Why not fill the premium car with premium gas?? Shell premium has Techron added in, along with Chevron and maybe Texaco. IMHO, adding Techron every 3rd or 4th tank is a huge waste of money, especially if youre using gas that already has it blended in!!
Once it's modifeid or tuned, though, best to stick with premium.
If you want maximum performance use what it's designed for, 91 or better.
I run 91 octane in my red 99 and 02 but always try and put 93 octane in my supercharged black 99. Before winter storage I use only non-ethanol gas. I put Techron in at least once a year.
if you're doing nothing but putting around at 15inHg or more of vacuum, then this is likely true... but if you're doing any decent acceleration, and/or it's hot or humid, or you're going up a hill without gearing down enough, etc... you're running the risk of pre-detonation (knock), which the knock sensors can sense & reduce timing after it's already started happening.
