Battery
Old Oct 29, 2023 | 07:37 PM
namvet6869's Avatar
namvet6869
Default Battery
Do you people remove your battery or put it on a trickle charge during the winter storage?
Old Oct 29, 2023 | 07:57 PM
3sACROWD's Avatar
3sACROWD
Battery maintainer
Old Oct 29, 2023 | 10:39 PM
hyperv6's Avatar
hyperv6
Battery tender
Old Oct 29, 2023 | 11:01 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
BatteryMinder
Old Oct 30, 2023 | 04:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Battery Sustainer
Old Oct 30, 2023 | 08:11 AM
hyperv6's Avatar
hyperv6
I think for the most you will find that most of us use a storage charger on our cars. They are cheap and easy to use. It maintains the power to the car over storage.
Most of us hook in the plug in cable that will make it an easy hook up with one plug.
Old Oct 30, 2023 | 08:40 AM
1972bluelt1's Avatar
1972bluelt1
Keep an eye on battery tenders and make sure the green light is on. Had 2 go nuts last winter, over charged and killed 2 batteries.
Old Oct 30, 2023 | 06:37 PM
Sebring Guy's Avatar
Sebring Guy
2023 C5 of the Year Finalist - Modified
Happened to me as well, boiled the battery. I just disconnect the battery now.
Old Oct 31, 2023 | 11:52 AM
With my C5s, I had the battery hooked up to a Deltran Battery Tender Plus - worked great.
For my C7, I use the factory CTEK branded battery tender.
Old Oct 31, 2023 | 04:07 PM
0DARK30's Avatar
0DARK30
I also use the Battery Tender Plus. I'm looking to get a Optima red top, you can still use this tender with it right?
Old Oct 31, 2023 | 05:09 PM
stavanger's Avatar
stavanger
Main power switch on the battery.
Old Nov 2, 2023 | 08:05 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
My C-5 is stored in a garage that's attached to my home, and which also has other cars parked in it, therefore I try to avoid as much risk as possible. I've been using Optima batteries in my car for years, so I bought an Optima charger, and in the winter, every 3-4 weeks, I put the charger on the battery and let it run through a charge cycle.
Old Nov 2, 2023 | 06:02 PM
grinder11's Avatar
grinder11
A word to the wise on those type disconnects; This came from C&S Corvettes. They had a C5 in their shop with one of those disconnects. It had been to another Corvette shop, and a GM dealer, before it got to C&S. Nobody knew why the car would stall, and not crank over to restart. It had an intermittent voltage issue. C&S figured it out immediately. The disconnect had a thread that wasn't machined all the way to a shoulder. It bottomed out before making a good connection. So make sure when you get one of these units, it tightens up all the way to the contacts, not until it just feels like it's tight.....
Old Nov 3, 2023 | 08:30 AM
captain vette's Avatar
captain vette
Disconnecting the negative have worked for me for the past 50 years and counting
Old Nov 3, 2023 | 11:02 PM
RedC5's Avatar
RedC5
I’ve never disconnected the battery with float charging - what is concern? Is it if the charger gets wacky messing up the car’s module?
Old Nov 5, 2023 | 10:42 AM
1972bluelt1
That was a concern of mine when 2 tenders killed the batteries in my LS1 firebird and C4 L98, but everything was OK.
To Battery
