Rhino liner
Old Nov 23, 2023 | 05:17 PM
99FRC Newb's Avatar
99FRC Newb
Default Rhino liner
Has anyone ripped out the carpet and just rhino lined the floor?
If you did, do you regret doing it?
Old Nov 24, 2023 | 12:33 AM
Curious as to why you would want to do this? Can't see this making the car's interior more attractive.
Old Nov 24, 2023 | 06:09 PM
vette4fl's Avatar
vette4fl
You're not being clear. What is the purpose of the rhino liner, and do you intend to recarpet?
Old Nov 25, 2023 | 11:58 AM
99FRC Newb's Avatar
99FRC Newb
I don’t intend to recarpet. It’s just to keep the floor safe and easy to clean.
Old Nov 25, 2023 | 12:29 PM
vette4fl's Avatar
vette4fl
IMO that’s a horrible idea.
Old Nov 25, 2023 | 12:52 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I agree. There are wires and connectors underneath the carpet that could get damaged plus it would look really bad. They have pre-cut replacement carpet available if your original carpet is trash.
Old Nov 25, 2023 | 02:29 PM
redzg's Avatar
redzg
In the bed of my old pickemup, a ‘79 F100, Rhino liner made the surface very rough and uncomfortable to the touch. It kept softer materials from sliding around, but made it easier to slide materials with little give, such as metal and hard plastic. Can’t really speak as to noise reduction — no chance I would have ridden around on it.
Old Nov 26, 2023 | 07:08 AM
Fast one's Avatar
Fast one
Or put a blanket down, just remove to clean it.
Old Nov 26, 2023 | 07:34 AM
grinder11's Avatar
grinder11
I would never do this, but that's obviously not how the OP is thinking. My .02....
Old Nov 28, 2023 | 08:37 AM
chevyvette98!'s Avatar
chevyvette98!
The Rhino lining could be an alternative to the sound deadening material that sticks on like Dyno Mat? I think it would provide some sound insulation, maybe not that much and also act as a heat barrier for the Heat Soak we all experience. Then I would definitely reinstall the/new carpet.
Old Nov 28, 2023 | 10:36 PM
99FRC Newb's Avatar
99FRC Newb
Wires aren’t a concern. The car is getting completely rewired when the Holley Dominator EFI goes in.
Old Nov 29, 2023 | 08:42 AM
redzg's Avatar
redzg
Your car, your choices. If you do go the Rhino route, do please report the results, both photos and a review of noise, temp, etc.
I’ve seen Rhino used for a variety of purposes over the years, sometimes it seemed cost effective, other times not. Will be interesting to see what a cost quote turns out to be.
Old Nov 29, 2023 | 10:44 AM
Rziesk's Avatar
Rziesk
WeatherTech? That's what I would look at...
Old Nov 29, 2023 | 12:34 PM
hyperv6's Avatar
hyperv6
No do not do it. Even in a race car it would be a mess.
Old Nov 30, 2023 | 12:33 PM
99FRC Newb's Avatar
99FRC Newb
The cost is the biggest factor for me. I have to replace the entire interior because I'm extremely allergic to mold.
I did just see that Speed Inc sells a full kit, so that is probably what I will use for the cost comparison.
Old Dec 1, 2023 | 09:36 AM
Fast one's Avatar
Fast one
Can the old carpet be removed and cleaned?
Old Dec 1, 2023 | 01:26 PM
RWH99Z51's Avatar
RWH99Z51
I've done it in a jeep wrangler. It made sense at the time, as it made it easy to spray out the mud that always found its way in there. The offset was that it made the jeep sound like I was driving an empty garbage dumpster around. You heard everything and it was horrible. I paid quite a bit of money to have it done as well, around $1,000 if I remember correctly. you could practically redo an entire corvette interior for that.
To Rhino liner
Old Dec 2, 2023 | 10:05 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
I did it to my Grand Cherokee, lined the entire interior. My intent was to help with rust and easy clean out after snow, salt and mud. Super noisy and hot inside, hear every thing. On an off road type vehicle I would have no problem doing it again, on a Vette I see no reason to.
Old Dec 2, 2023 | 02:29 PM
c5arlen's Avatar
c5arlen
Perhaps one could put ryno stuff in your truck?... Or tractor. 🙄
Old Dec 4, 2023 | 04:25 PM
99FRC Newb's Avatar
99FRC Newb
Thanks! This is the type of feedback I was looking for! Thank you for sharing your experience. I'll definitely look more into just replacing the interior. It looks like Speed Inc. sells a full set for just under $800.
