Sagging Headliner - Painted Roof
Old Nov 30, 2023 | 08:02 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default Sagging Headliner - Painted Roof
I have a sagging headliner in my C5's pained roof, recommendations for a fix?
Anyone used this: https://www.southerncarparts.com/199...headliner.html
Old Nov 30, 2023 | 09:22 PM
Frank4202's Avatar
Frank4202
I had the same problem in my 97. I ended up removing the liner, cleaning it the best I could, and reinstalling it with can spray adhesive. Looked great cause I took my time. I had the car 3 more years before I sold it and it still looked great.
Old Nov 30, 2023 | 10:23 PM
RichMisner's Avatar
RichMisner
I pulled down the headliner, sanded the underside and painted it - I have to say that I'm much happier now that it isn't falling on my head on a weekly basis! I've thought about taking it to one of our custom paint shops in town to have something airbrushed on there, I think that would look pretty sweet.
Old Nov 30, 2023 | 10:37 PM
noahdr's Avatar
noahdr
The foam in my original headliner fell apart. I glued it back up once, but it didn't stay up for long. I ended up peeling the old liner off, and put in some generic headliner fabric. It turned out really well.
Old Nov 30, 2023 | 10:51 PM
hyperv6's Avatar
hyperv6
Do not reglue.
Remove the headliner and clean the foam off the base. Go to a fabric store and purchase new foam based headliner material and use 3m interior adhesive to install it.
This will restore it to like new for less than $30.
Old Dec 1, 2023 | 12:56 AM
^ Good tip and hard to beat the price.
Old Dec 1, 2023 | 12:52 PM
MSOH's Avatar
MSOH
Veteran: National Guard
Vader, over in the "What did you do to your C5 today" thread, post #14419 I posted how I fabbed a new headliner for my car. I'm horibbly tech unsavvy and could not figure out how to link that post to this thread. If you're interested take a look and I can fill you in on any finer details if you want. BTW, if anyone knows how to cross link threads, I'd love to know!
Old Dec 2, 2023 | 08:03 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Mine started to "droop" 2-3 years ago. I carefully removed it, cleaned the backside of it, and reattached with several pieces of 3M tape. It was OK for a while, but I notice that it's starting to fail, again.....
Old Dec 2, 2023 | 09:49 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Mine ended up on the side of SR-72 in Florida after falling on my bald head and scaring the **** out of me at 80 mph, second failure to stay up. I ended up cleaning, sanding and painting the inside roof panel with a satin black spray bomb, looks great!
Old Dec 2, 2023 | 01:14 PM
hyperv6's Avatar
hyperv6
Here is a good video on how to pull this and do it right.
use care with the boards as they can be fragile and use new foam backed material to get the best results.
Cloth over a bad service will show through.
Re gluing and not replacing the foam will let the glue soak into the material too.
This same thing will work on Z06 but you will have to remove more interior to get the board out.
I have done this on a number of cars even with TTops ans it works well.
Cloth stores will have grey, black and often a ran color.
$30 for cloth and glue.
just do not short cut if the foam is bad as the results will be much less than good.
Old Dec 2, 2023 | 04:50 PM
Johnny Hardcore's Avatar
Johnny Hardcore
If the foam on the underside hasn't started coming apart and everything is intact but it just unglued...3M spray adhesive will do the trick. Mine started separating in 2008. I used 3M spray adhesive and it hasn't had an issue since. At least 30k miles of driving with that top on since the fix.
Old Dec 2, 2023 | 05:41 PM
MSOH's Avatar
MSOH
I used EV foam sheet you can get at HobbyLobby. It cuts easily and is sandable for fine tuning. Here is what my foam backer looked like prior to covering: Got the headliner material at JoAnn Fabric and all in all I would agree I've got $30-40 in the whole project.
After covering with the headliner material
Old Dec 3, 2023 | 11:09 AM
oh1vette's Avatar
oh1vette
I used the back padding and glued some leather look material matching my light oak interior
Old Dec 3, 2023 | 11:28 PM
CorvetteFan1953's Avatar
CorvetteFan1953
2024 C6 of the Year Winner - Unmodified
Pull it down, clean off the surface of the top, and use spray adhesive. Good as new!
Old Dec 4, 2023 | 12:21 AM
MosEspa's Avatar
MosEspa
Took mine to an upholstery shop and they were able to replace the headliner with the same materials GM used on them. At least that's what the guy said - Said the foam was some kind of weird flame-retardant material that is hard to get now a days. Anyways, from all the C5's I have driven it's identical to them but just... brand new. Was not super expensive either.
To Sagging Headliner - Painted Roof
